![]() | Home > Technical (L322) > TDV8 Turbos |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
YOU have made this perfectly clear ![]() And we are not talking about 10 minutes of idling. We are talking 60-90 seconds I suggest you take a little of your own advice here, Craig ![]()
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3887 ![]() ![]() ![]() |
If you drive in such a way that you need to allow your diesel turbochargers to cool, I would suggest you get a 5L Petrol --- like me |
What about those who want a decent turn of speed, but still half decent fuel economy? |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Interestingly enough. When you switch your ignition off in a supercharged car. Your supercharge rstops spinning instantly.
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Some of the "quotes" are contradictory, some say atleast 3-5 mins then another will say no more than 2mins!
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1053 ![]() ![]() ![]() |
I'm in the same camp as RJH. Car serviced in accordance with service schedules and oil regularly checked (mine doesn't use a lot). My FFRR is used mostly for long journeys so runs for long periods at high operating temps. One the last bit of the journey, which is almost always on quiet lanes or suburban roads I just bumble along letting things cool down; with the radio off you hear the glorious engine note just waffling quietly, so another reason for doing it. Pull up and leave it running for another half minute or so, lower suspension, gather bit sand bobs, switch off. I'm sure others think I'm nuts, but I've done the same with all my turbo diesel cars and never suffered a turbo failure. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
From various threads on here, the culprit seems to be egr issues which causes the turbos to over spin which stuffs one and then overloads the other. So can the egr's be removed like on the td5 and td6 and mapped out ?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
I'm wondering if it'll rain tomorrow.
I'm just trying not to keep walking under the rain cloud..... If you remove the rain cloud, you'll never need a brolly.
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
I'm asking the same question myself.
Blade74 there is a post about removing EGRs on TDV8 engines on here, have a look. I can't remember the gist of it but I think it sounded quite an undertaking IIRC.
A feature on turbochargers from the latest Car Mechanics magazine...
FullFatDunc Member Since: 16 Aug 2015 Location: South Somerset Posts: 65 ![]() ![]() |
How does this cool down work with the Eco stop/start then.
Long story short, it WILL impact upon the lifespan of the turbos.
