Home > Maintenance & Mods (L322) > Wabco Sintered Brass Filter (yr=2002)
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Does anyone know if you can get this item replaced
On the later (2006 models ) I see it has a hex shoulder for unscrewing but this is just round.
Long nose pliers can rotate it but obviously starting to crush the brass.
I was just trying to make it better - my intention was to remove and clean it but things are going downhill so any idea of replacement / service strategy Smile
Thanks. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #348057 16th Sep 2015 5:28pm
dingg1
just drill a hole in it , its only a noise suppressor
Post #348058 16th Sep 2015 5:32pm
Could you post the thread size please so that I can order one as well. Thumbs Up Thanks
http://www.ebay.co.uk/itm/Conical-Silencer...19ceeb3cd0
Post #348089 16th Sep 2015 7:23pm
SMUTT
dingg1 - Thanks for the reply Smile I was not too sure if it was exhaust only or also inlet, if exhaust I only I shall follow your advice. Simples.
NDFI - it does not appear to be threaded - I suspect it may be barbed and pushed in - does not seem to want to come out easily - tried levering near interface joint with sharp chisel - no movement - only slowly destroying the sintered brass - soon to be solid brass Big Cry
Since I will remove to drill it - Going to do the whole Bagpiping Andy kit on the piston - nice kitchen table job for the darker nights! Howard
Post #348099 16th Sep 2015 8:00pm
