Home > Technical (L322) > Help!!! inactive EAS 05 Vogue |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Dare I say it ... fuse ... but I guess you already tried that? Howard
16th Sep 2015 5:13pm |
leeroyburns Member Since: 16 Sep 2015 Location: Northern Ireland Posts: 8 |
Yes fuses, relates etc all checked, it's like the EAS is asleep |
16th Sep 2015 5:35pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2581 |
Pump? |
16th Sep 2015 5:39pm |
Yes pump is operating / was told if you can force air into the system it should start to come alive but we can't get air into it! |
16th Sep 2015 5:42pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Have you tried bye-passing the compressor relay?
16th Sep 2015 6:13pm |
No I haven't , never thought of that - that will eliminate any problems that end 👍 I'll try anything now |
16th Sep 2015 6:16pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
If there are no lights on the EAS switch then its a hard fault that needs checking and clearing with a diagnostic tool before it will work again. |
16th Sep 2015 6:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
as weejock says, clear the hard faults first .
16th Sep 2015 6:54pm |
Just a thought has it gone into transport mode? Howard
16th Sep 2015 8:28pm |
That did come across my mind- any suggestions how to get it out of this mode? |
16th Sep 2015 8:42pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 338 |
Agreed |
16th Sep 2015 8:43pm |
My mechanic did try to connect it to the computer but it picked up everything but the EAS - is this a landrover job? |
16th Sep 2015 8:57pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
im sure this has been checked, BUT, have you reslammed all the doors, bonnet, and tailgates etc. these need to be all shut, (doors at least) for it to even 'get out of bed'
16th Sep 2015 10:25pm |
