Home > Technical (L322) > 02 L322 Unable to Calibrate the Air Suspension - RSW |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
the front should be one cm higher than the back , is this what you mean.. ... - .- -.
11th Sep 2015 11:21am |
rgwatches Member Since: 19 Dec 2012 Location: United Kingdom Posts: 36 |
It was probably fine but a subsequent attempt raised it up to near what would be considered the high setting whilst in normal, it now won't calibrate. |
11th Sep 2015 11:26am |
Transpires I was being an idiot and not factoring in the additional size of rims (22") and subtracting that from the input measurement (thus bringing it within the software's parameters (no greater than 840mm!).
16th Sep 2015 1:21pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Great to know you got it sorted - Thanks for posting back the result - was going to re-calibrate my suspension with RSW and was having second thoughts after your initial post. BTW - RSW himself is usually quite responsive (in my experience) if you find a problem with his unit so sometimes worth emailing him directly Howard
16th Sep 2015 1:36pm |
I was giving the forums a bash before I contacted RSW, I've done this a few times, what threw me was the new wheels (old ones were 20").
16th Sep 2015 1:47pm |
Thanks. I was giving the forums a bash before I contacted RSW, I've done this a few times, what threw me was the new wheels (old ones were 20").
16th Sep 2015 1:48pm |
