Home > Technical (L322) > Dead key fob after 3 mths without use |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Go down to Dan -UK's post for the how to , it sound like the key is out of sync .
12th Sep 2015 1:13pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Thanks for the reply. I couldn't get the key to unluck or lock the car. ______________________________
13th Sep 2015 7:18am |
So did you re-sync the key then ? 2008 MY Supercharged
13th Sep 2015 9:24am |
Yes, I followed Dan's procedure as follows:
13th Sep 2015 11:44pm |
As long as you don't make the mistake of turning the ignition off between keys you are doing everything right , try a battery reset and persevere a few more times . I had the same problem and took it to the stealers to be told I needed new keys , $1700 here unlike the 170 GBP everyone else pays so I took it home and tried again with the re-sync which worked this time .
14th Sep 2015 4:45am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2524 |
For your phone if its still not working properly, try pairing a different phone then try your one again. Even my MY12 fussed when first pairing my phone, but fixed after pairing the dealer's phone then mine again.
14th Sep 2015 5:30am |
I gave the key procedure another crack without success. I've given it back to the mechanic this morning. He will autologic it without charge to sync the keys. Thanks anyway.
16th Sep 2015 11:04pm |
