Home > General > TD6 Aux Fuel Burning Heater Question - newbie 1st Post!
dan_uk_1984
You also have to consider your resale in a few years time, no one wants the HSE now let alone in the future. Also I didnt think Bi-Xenons were standard on the HSE? But may be wrong on this, my brain is frazzled from all the xenon/bi-xenon/halogen talk recently.
You get MUCH nicer seats in the Vogue as well as heated steering wheel and heated rear seats as standard, I believe these were options on the HSE. You'll also get the 13 speaker Harman Kardon sound system vs the 6 speaker bogo unit.
DVD player is Autobiography only I'm afraid Razz Although I paid less than your budget for mine with a FBH standard!
Post #34742 3rd Nov 2010 5:34pm
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Im a bit confused here Whistle
What do I need, to get mine working?
I had a look at the option on the nav screen this morning and all Ive got is aux ventilation
Post #34823 4th Nov 2010 12:39pm
dan_uk_1984
Depends what components you have already and what functionality you ant to get out of it?
Do you want the timer, or do you want the remote? Or both?
Do you already have the loom behind the fuse pannel in the boot? Have you looked at the workshop manual to see the component location diagram? You should then be able to see what bits you already have and what bits you need. If you read the link I posted about the discovery pre-heater the theory is the same...
Post #34830 4th Nov 2010 1:20pm
doublejay
Quote:
I'm sure the RR fully fledged version
close....it's Full Fat round these parts. Thumbs Up
Welcome along.
Post #34840 4th Nov 2010 2:24pm
4x4 Beetle
Welcome along.
Well spotted that man - full marks (or is that full fat) for observation - I like to see that hence I previously wrote Xenons are fitted as standard to FFRR HSE, which of course, they are Thumbs Up
This FBH issue throws up a myriad of variables Confused
Post #34869 4th Nov 2010 4:44pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I wish I had read this post and the wiki before.
I have just sat in the FF on the drive with cold air blowing into my face for the last 15 minutes (assuming that Aux Ventilation was some kind of heater) - I think the neighbours think I've lost the plot......
On a serious note, I will be interested to know if Aux Ventilation has many / any uses? Does anyone here actually use theirs for anythng constructive?!
And on my last point of trivia, has enyone else noticed that the 5 x EAS lights are very very faintly lit whilst the ECU is still awake?
Yawn 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #161686 3rd Jan 2013 7:27pm
spanner
Aux heat and vent can be activated in a HSE and can be set on the mid unit or by remote activation if you plug in the reciever and get a fob what you will need is the ecu programing
Post #161691 3rd Jan 2013 7:39pm
Dolphinboy
cool. how do you set it to come on automatically using the MID unit?
Post #161695 3rd Jan 2013 8:02pm
spanner
when ecu programed you have 2 selections on mid HEAT and VENT you just put the time you want it to come on same as you do with sat nav screen
Post #161697 3rd Jan 2013 8:07pm
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
get yourself a range rover and get the idea of a shogun out your head, they are just not in the same league. Whatever spec you are happy with, thats in your budget then go for it. I will be looking for one sometime soon and dont have money to burn, so at this moment i would be happy with any range rover because driving a range rover is what i want more than all the fancy specs!
Post #161718 3rd Jan 2013 9:18pm
Dolphinboy
Ah, but spanner, the HSE only has a single Cd slot and no full screen as in the vogue so how do u set it using the display? Shocked Confused
Post #161761 3rd Jan 2013 11:33pm
spanner
when the ecu is programed it gives you the extra vent and heat options and you select them via the buttons under the mid display you also set the time for it to come on using the buttons
Post #161771 4th Jan 2013 7:19am
Dolphinboy
cool. Now I understand. Thumbs Up
how does one get the ECU programmed to do this? does it need a stealer?
Post #161852 4th Jan 2013 1:22pm
