Home > Technical (L322) > Speedo Issue
Mikey
The discrepancy comes between the ABS/VDM and IPC
The above readings were taken from my Disco 3, with the cruise set at 70mph on the speedo
GPS had it between 66-67mph, so the wheel speed sensors are accurate enough
On some models, there is the option to adjust the speedo offset, to make the differences in speed smaller, and more accurate Thumbs Up
Post #347356 12th Sep 2015 10:14am
Alex Millar
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Mikey I understand but my car speedo registers 30mph when a satnav in the car shows 36mph. On travelling on motorways I set the cruise at 65mph to do 70-75mph, which as you say should be the other way round.
Is it possible to readjust the electronics of this?
The car has 255/55/19 tyres as it now has 19 inch wheels on it, but I don't think that should affect things as the rolling distance will remain the same.
Post #347389 12th Sep 2015 2:05pm
Mikey
Most speedos are set the other way, to read faster than you are actually travelling... Confused
Post #347404 12th Sep 2015 4:06pm
Alex Millar
That's my problem - the speedo in this car is working in the opposite way to all other cars I have had. It is not a major issue as in a line of moving traffic I get used to travelling at 25-30 (actually30-35) or 35-40 (actually 40-50). My concern as is probably yours also is the average speed cameras on the A9 where you have to be careful not to drift above the limits.
Post #347435 12th Sep 2015 6:08pm
Mikey
Cameras on the A9 are a complete Censored
I don't know if there is a setting for the pre-10MY L322 to adjust the speedo offset.
I know there is in the RRS/D3/D4 and newer L322
Post #347442 12th Sep 2015 6:27pm
Alex Millar
Thanks - speak to my local indy and ask him to have a look
Post #347447 12th Sep 2015 6:53pm
Mikey
Depends what diagnostic kit they have. I know Autologic couldn't adjust it, last time I used it...
What MY is your car?
Post #347459 12th Sep 2015 7:50pm
Alex Millar
It's a 2003 V8 4.4. Only been in my ownership 3 months to replace my old faithful Disco series 1.
Post #347461 12th Sep 2015 8:20pm
