Home > Technical (L322) > Speedo Issue
Flunter
England 2003 Range Rover Vogue Td6 Oslo Blue
Speedo Issue
Me again Smile
After the initial hiccups the last 4 months have been trouble free (knock, knock) but one thing is beginning to drive me nuts.
My speedo always shows 5 mph below my actual speed i.e. 25 @ 30, 35 @ 40 etc., any idea why?
Just to clarify, everything is standard, wheels, tyres etc., the speed has been checked following other vehicles and, to be honest, after 35 years of driving you know your speed within a couple of mph.  Not Representative!
Post #274148 3rd Aug 2014 8:44pm
pld118
What's telling you you're doing 5mph less than you think it is doing?
Post #274151 3rd Aug 2014 8:57pm
Flunter
Erm, the speedometer display.  Not Representative!
Post #274152 3rd Aug 2014 8:58pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
@ Pld...was thinking the same ..
@ flunter...Do you have 2 different indicators of speed? One being the speedo and the other being.....?
Ie how do you see 2 different speeds to know there's. A 5mph difference...sorry i may be being thick. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #274154 3rd Aug 2014 9:06pm
pld118
If the speedo display displays 30mph, how do you know it's only doing 25?
Post #274156 3rd Aug 2014 9:07pm
Flunter
As I stated in my initial post, I've checked the speed by following other vehicles. When they're doing 30 my speedo shows 25, and the same at other speeds. I checked it against 3 different cars with the same results.  Not Representative!
Post #274157 3rd Aug 2014 9:08pm
paulmoran2
Ah...understand now...the wiki has a workshop manual and you may get a clue there, but obvoius stuff like tyre wear will make a difference. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #274158 3rd Aug 2014 9:10pm
pld118
Wasn't clear to me in the OP. Sorry.
Post #274161 3rd Aug 2014 9:34pm
Whilst I find your methodology in determining your vehicles actual speed somewhat dubious, can I suggest in the first instance that you have the car plugged into a diagnostic unit to check if any faults are logged on the ABS system.
Post #274163 3rd Aug 2014 9:45pm
first port of call would be to buy or borrow a stand alone sat nav and compare your speed to that.... ... - .- -.
Post #274167 3rd Aug 2014 10:00pm
RR2008HSE
I agree with Stan. So many phones have gps, it should be easy to get a passenger to test to for you at a variety of different speeds.
I have that issue with my Disco, but I have oversized tyres that cause the difference.
Post #274174 3rd Aug 2014 10:45pm
You say you have standard tyres... What size are they? Previously..
Post #274182 3rd Aug 2014 11:18pm
Alex Millar
I have the same issue. Checked by using another satnav and speed display signs on roadside and roughly 20% below actual speed is being registered on speedo. Not sure how to correct it or just live with it Rolling Eyes
Post #347340 12th Sep 2015 9:20am
Mikey
The speed display signs are not particularly accurate...
Post #347354 12th Sep 2015 11:11am
Like most people my speedo over reads by a tad ( normal ) but if I set a speed warning bong it goes off right on the money , have you checked that ? 2008 MY Supercharged
Post #347355 12th Sep 2015 11:12am
