Home > Technical (L322) > TD6 Stuck in gear. |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 |
Yikes, that sounds like a pickle!
10th Sep 2015 11:20pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
Have you tried manual mode? |
11th Sep 2015 5:08am |
Numb Member Since: 29 Dec 2013 Location: West Coast Posts: 35 |
Hi, yeah tried manual mode but it won't change gear, the dash indicator shows the numbers changing but it just jumps back to 2nd after a few secs. Will give the battery reset a go. Cheers. |
11th Sep 2015 7:33am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
If your stationary in manual mode the car will always revert back to lower gears after a few seconds sir... Self preservation! Why would it try pulling away in 4 or 5? It would at best damage it! At worst destroy something inside...
11th Sep 2015 7:44am |
Hi Cam Tec, Yes, in P I can stop, start remove key, it won't rev properly at all, if I give it any revs it just wants to surge forward. I can also stop and start the car in N to, but the car still wants to pull forward no matter what is selected. Not looking good, poss gbox change? Thanks. |
11th Sep 2015 9:06am |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 32 |
Numb, of general curiosity, are you able to ignite the car when the gear selector is on "R" or "D"? What happens then? My TD6 gear box has once played a trick on me so that the car started to reverse vigorously on "D" after releasing the foot brake at the traffic lights. I cycled through all the gear lever positions and the box went back to normal. This has happened only once to me (during the first week of ownership). Since driven over 8000 miles and no problems whatsoever with the gear box. |
11th Sep 2015 10:21am |
Hi Sass, no, the car will only start in P or N. Got car plugged in to diog and no error codes found This is not a good start my FF experience. |
11th Sep 2015 10:43am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Might be worth reading this and greasing the gear linkage cable. You might be lucky.
11th Sep 2015 10:48am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
maybe a battery reset? ... - .- -.
11th Sep 2015 11:07am |
Gear linkage was done when I got the car, all smooth and as it should be, will give the batt disconnect a go but I ain't hopeful. It seems like some kind of mechanical lockup. Will drop the oil on Monday and see if there is any metal in it and take it from there. The next saga will be to see what the dealer I bought it from wants to do, as it's over 400 miles away I'm hoping they will send the bits required and let the local Indi garage fit it. |
11th Sep 2015 4:56pm |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 |
If you are near glasgow pop in to mackie auto very helpful . Tollcross area of glasgow |
11th Sep 2015 6:30pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1765 |
Hate to be the bearer or bad news, but the gearbox has itself...
11th Sep 2015 7:13pm |
Yeah, that's what I thought, I think Mackie's in Glasgow will be the closest and best for a rebuild, Any other recommendations would be welcome. I'll have to contact the dealer on Monday and see what there take on it is as i have only had the car just over three weeks. I hope we can come to some arrangement to let my own garage do the work, as I know his work is spot on, rather than the cost of a 400 mile recovery I hope to keep the FF a long time and I want the best job done on it, rather than a quick fix. Thanks |
11th Sep 2015 11:08pm |
A quick update, drained oil before removing box yesterday, very black and smelt of burnt toast. Lots of sludge in the oil which glistened in the sunlight like metallic paint, a few slithers of ally in there to, not good. Box sent away for refurb curtesy of the dealer. Hopefully won't take to long as I'm missing the rangie already. |
16th Sep 2015 11:42pm |
