Home > Maintenance & Mods (L322) > The search for the coolant leak.
Well started the search for my coolant leak and I currently have the inlet and water valey stripped. Have found many small leaks. Will post some pics later. But it's going good. Fill you in later. Loads of pics for you.
Post #72651 16th Jul 2011 12:05pm
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
will be very interested your findings Rob2529 Thumbs Up
Post #72655 16th Jul 2011 12:35pm
pretlove
yes me to "RANGEISM WILL NOT BE TOLERATED"
Post #72657 16th Jul 2011 12:45pm
Will put pics on when I get in. Up to now a very straight forward job. Big but simple enough. Looks worse than it is. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #72669 16th Jul 2011 1:59pm
Start with engine cover removed
Few ref photos of LPG system
LPG system removed and pax side coils and injector loom removed
Inlet manifold removed showing valey and coolant tubes.
Inside inlet manifold looking towards the throtal body
PCV removed shoing idle valve inside intake manifold
Inside intake manifold with idle valve inplace. See where it connects to the front of the inlet manifold.
Valey shows signs of leaks down the left hand side. PCV hose at the back has leaked oil all down the left side
Valey pan removed along with rear water manifold and tubes.
Manifold with new gaskets and "O" rings.
These are the 2 hoses of the PCV. Large one off the cyclone other off the inlet manifold PVC. Mine were all shot so replaced with some new ones
New valey pan and tubes all cleanedand conected. Water manifold back in place
This as far as i have gotten today. Inlet manifold to go back on and re-wire.
[/img] [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #72690 16th Jul 2011 8:44pm
Trist78
2004 Range Rover Vogue 4.4 V8 Java Black
Looks very time consuming
How many miles has your car done ?
Post #72693 16th Jul 2011 10:03pm
She's done 91k. Took about 3 hours to strip so hoping it goes back together today a bit quicker. Took most of the day to get where I'm upto with stripping and then prepping and cleaning ready for rebuild. It's actually a simple job. Think the biggest spanner was a 13mm an that was for removing the pollen filter housing. Everything else was a 10mm. I got quoted 4hours by my local Indy which is probably doable if you do it every day. We lost alot of time disconnecting the injector haness's. They are in a crap position and have the cOnectors with the metal retaining clip but there the worst way you could think! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #72703 17th Jul 2011 6:26am
Trist78
What bits did you have to buy to repair the leaks was it just the o rings !
Post #72752 17th Jul 2011 7:58pm
Jobs complete. No leaks as yet but its early days Whistle . She now runs better but what its down to im not sure. I replaced the PCV valve and seals, so hopefully thats what's caused it. After i had put her all back together she started first time which was a relief. My knees are black and blue, have cuts all over my forearms and a swore head from leaning on the scuttle. the list of parts i used were:
Valley Pan = LCW00001 (11141742042)
WATER JACKET (black plasstic valey cover) = LDR000350 (11141736106)
INLET GASKET (x4) = LKJ000040 (11611433328)
INLET MANIFOLD FRONT GASKET = LKJ000050 (11611729727)
INLET MANIFOLD REARGASKET GASKET = LKJ000060 (11611729728)
PCV = LKR000040
COOLANT HOSE O RINGS large (x2) = PYX000040 (11531710048)
COOLANT HOSE O RINGS SMALL (x2) = PYX000050 (11531710055)
COOLANT MANIFOLD GASKET (x2) = PET000030 (11531731833)
SPACER (inlet manifold) x10 = LYF000110 (11611736648)
VENT PIPE RING = LYX000150 (11611745195)
PCV VENT GASKET = LWF000010
* BMW part numbers in brackets
As it turned out i never used the PCV vent gaskets as they came already fitted to the PCV itself. I never used the front inlet gasket as i never had the 2nd gasket needed for connecting the throttle body to the spacer. If i was to do the job again i would have got the other 2 hose's for the PCV. The bottom hose of the cyclone was rock hard and no good and the 2nd hose of the PVC to the sump was shot and caused the oil leak down the RH side of the valley. I got some hose from halfroads that will prob be better than standard but we can only hope.
The leaks i had were from the valley pan, where the hose leaves the rear water manifold, and 4 tie ins for the LPG system.
i used this website as a guide: http://www.members.cox.net/rlacm/IntakeIndex.htm Its a break down from a 5 series and a lot isn't relevant to us but its a good guide and has a lot of useful hints and tips. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #72757 17th Jul 2011 9:15pm
swast4
Good post Rob, I hope it's sorted your leak.
Post #73164 20th Jul 2011 11:23pm
verydisco
Hi did it sort it out then?
tx l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #316442 5th Mar 2015 8:52pm
Hi
Sorry for the late reply but yep sorted the leaks. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #345074 29th Aug 2015 11:37pm
