Home > Maintenance & Mods (L322) > Fitted the brembo 6 pot upgrade today, with write up and pic
Page 2 of 4 <1234>
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Don't worry, we were/are both Censored .
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #344217 24th Aug 2015 8:32pm
sasdiscos
Andy. It was a right pita. I wonder if they could be replaced by stainless bolts? Would make it easier. I put copper grease in mine when I put it back together. I'm hoping this will help next time. You remind me of a young me, not much younger mind, perhaps even a little older!
Post #344347 25th Aug 2015 3:48pm
sasdiscos wrote:
Oh, and Stan, many thanks for the thumbs up. More than can be said for some other people..... Rolling Eyes
Sorry Steve, I've updated my original post.... Whistle
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
P.S. You left your locking wheel nut key on the wheel in that last picture, hope you remembered to take it off before you went out for a drive..... Pete
Post #344361 25th Aug 2015 5:22pm
Sorry, just read your last post.... did hear when I had the Merc with alloy callipers that you shouldn't use copper based anti seize as it rots the alloy, they do a special one for alloy.... Pete
Post #344362 25th Aug 2015 5:25pm
sasdiscos
Haylands, wasn't referring to you matey, so unsure of what the updated post was about. I was actually referring to my wife at the time but as I had had a few I didn't finish my post. Very Happy
And I didn't know that about the copper grease. Looks like ill be stripping it all down again then. Still think it might be better to drill out and put in a stainless steel bolt.
As for the wheel nut key, yup I did remember to take t off, Im actually thinking of binding them off all together and just replacing with normal nuts.
Apparently lots of people have had them shear off, this is being due to them being made in two parts, then leaving you to drill out the nut. Not good.
Post #344664 27th Aug 2015 6:51am
Andy B
I did the same Steve.....lets hope it doesn't melt the calipers! SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #344673 27th Aug 2015 7:43am
sasdiscos
I've done some research on copper grease on alloy and I can't find any evidence that it will be a problem.
Fingers crossed.
Post #344793 27th Aug 2015 5:46pm
wokkadriver
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
A grand looking job there, Steve - what did you use to paint the callipers with?
Post #344814 27th Aug 2015 9:40pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Re: Fitted the brembo 6 pot upgrade today, with write up and
Looks good mate, nice write up.
Hope you didn't forget to remove the locking wheel nut lock mate.
I have experience from an old car in the past, believe me it's a pain in the neck! Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #344836 28th Aug 2015 8:45am
sasdiscos
Yes, locking wheel nut removed Laughing
Paint is two pack. Don't know the actual red tho. I can find out.
Post #344858 28th Aug 2015 10:42am
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
HI all,
I'm ready to do the upgrade to my up-to-05 FF with the BMW calipers.
I'm going to use the 4-pot Brembos from a 4.2 SC/3.6 TDV8.
I cannot find a reliable source online however as to what the part numbers are for everything. Backplates especially seem an issue as no-one seems to know if the 4-pot backplates and discs are the same size 6-pot ones, or a size inbetween these and the smaller BMW ones. I'm also struggling to find a caliper part number, I dont trust searching by model type/year as I know some TDV8s had awful 2-piston calipers for a while!
I know that the easy way around the backplate problem is to trim the existing plates, but mine need to come off anyway as they have rusted to pieces so I want to replace them properly!
Finally, I assume the brake hose fittings on the caliper are the same as on the BMW ones?
Ta,
Matt NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #378149 18th Mar 2016 11:43am
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
I have a 2009 face lift ff se vogue tdv8 3.6...will this upgrade be ok for it 😁😁😁😁
Post #523449 31st Jul 2019 6:24pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
mat777. Let us know how you get on fitting the four pot Brembos. As I wouldn't mind swapping mine next & would like to see how it goes Thumbs Up
Post #523461 31st Jul 2019 8:43pm
L_G_D
Poland 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi, can I make P&P uprgade from 4 pot brembo calipers (3.6 tdv8 2008 model) to 6 pot brembo calipers?
I need to do this:
1) 6 pot calipers
2) discs
3) dust shields
4) Pads
5) difrent sensor
I have a whole used set to buy from a 5.0SC 2010 model and I wonder if it's worth it
Post #548678 29th Mar 2020 12:56pm
NO sir... The six pots wont fit as the hub bolts for the six's are much bigger then those on the four pots...
Post #548691 29th Mar 2020 2:55pm
Page 2 of 4 <1234>
