Home > In Car Electronics (L322) > Replacing the twin subs |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
IGNORE |
24th Aug 2015 9:26pm |
nope will try ringing baris again today cant get hold of him |
25th Aug 2015 2:57pm |
got hold of him coming to me tomorrow so will update you |
25th Aug 2015 3:26pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Did u have any luck fitting the upgraded units?
26th Aug 2015 11:14pm |
Yes matt i have
27th Aug 2015 8:04am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
A good job done there.
27th Aug 2015 8:45am |
That's good think I'll save up and have mine upgraded too.
27th Aug 2015 9:58am |
Smegordead Member Since: 26 Mar 2013 Location: Maidstone, Kent Posts: 27 |
I had the BM54 to stage2, aux socket, Ipod 30 pin, 4 channel RCA pre out and bluetooth (this is a tunestream unit on another 30 pin cable) AND the TV turner upgrade, originally I went for a stage 2 conversion with extra antennas but have since downgraded to stage 1 so I can have a reversing camera and video-in working OK.
27th Aug 2015 12:17pm |
yes a write up would be good!!
27th Aug 2015 12:35pm |
Matt,
27th Aug 2015 12:53pm |
Very interesting thanks for your input, is the oval speaker really a worthwhile upgrade.
27th Aug 2015 9:47pm |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
one thing to note about subs is that most are generic in as much as they will play all low frequencies okay but not great ,the type of music you listen should dictate the size of the speaker,If you listen to a lot of drum and bass tye music with long low notes you would need anything from 12" and above and if you like rock music with has a tight punchy bass you should be looking between 8" and 10" I always found a good active crossover works best with audio this is kind of like the DSP except you it would come after the DSP and Before the Amps. The whole car system could be upgraded and still look factory fit except for the subs most companies do head units now with parametric equalizers built in so you just put a mic where you head would be or where you want the music to be focused and it will work out the rest |
28th Aug 2015 7:03am |
Any news on how the system sounds with the new upgraded amps yet?
6th Sep 2015 10:58pm |
