Home > Technical (L322) > Lower arms again
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Lower arms again
I've just had my ff in at the main stealers to get the air con diagnosed and the front knocking confirmed to be what I thought it was , and yes it the lower rear front control arm . The price is £156 from the dealer down to £20 off fleabay there is als the other option of polybushing the arms ,I've read somewhere that polybushing doesn't work well on the ff so I'm after the pros and cons
1 main stealer
2 cheap fleabay patten part
3 polybushing
Post #344604 26th Aug 2015 8:24pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I'm keen on the thoughts of polybush for replaced bushes now they are available, what's the consensus?
Matt
Post #344641 26th Aug 2015 10:55pm
Ivor
found this on a muddy website not sure how applicable it would be to a FF living 90% of the time on the road http://forums.lr4x4.com/index.php?showtopic=78917
Post #344644 26th Aug 2015 11:18pm
IMHO total waste of money, ONLY buy original bushes.... believe me I have tried them all over the years and you cannot beat genuine ones... Pete
Post #344651 27th Aug 2015 12:47am
ebajema
Why not shop around for the arms, talk to Dan at Duckworths, he will give you a good price I'm sure. Then let an indy do the work. I had the mechanics in Nigeria do both front rear control arms on the 4.2 and it turned out to be a relatively easy job (the front bags failed and that is when we noticed the rubbers being in "not great shape"). MY 2010 5.0 SC Galway green and sand interior!!
Post #344653 27th Aug 2015 2:11am
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
The only reason I brought polly bushes when I had my challenge defender was because they were easier to replace.
They don't last as long as the real thing and certainly don't feel as good.
Steve. You remind me of a young me, not much younger mind, perhaps even a little older!
Post #344667 27th Aug 2015 7:01am
Ivor
thanks for the opinions guys I plan on doing the work myself as i'm pretty handy with a socket set and hammer
Post #344678 27th Aug 2015 8:00am
Get a price off Dan for OEM Delphi arms. Probably what were on it originally.
From memory they were quite reasonable, also is it the large bush at the back of the arm or the ball joint at the hub end?
Both are changeable separately, though the ball joint is fairly straight forwards the big bush needs pressing out, and everyone I have spoken to in it says don't bother just buy the arm.
If you are doing it yourself make sure it's on the ground before tightening the big bolts so the bushes are in the right orientation! There is nothing that can't be fixed with a hammer😜😜
Post #344683 27th Aug 2015 8:16am
verydisco
I went for genuine complete lower arms and do not regret it al tall: Go genuine via Dan Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #344719 27th Aug 2015 10:34am
I rebushed the lower arms and as has been said above.... don't bother... took ages, was a right pain even with a 10ton bench press, it saved a few quid but I wouldn't bother next time..... Pete
Post #344772 27th Aug 2015 3:49pm
Ivor
Well I had a day to day when nothing can go wrong so I phoned the garage the I bought it from and they are going to do it all for me
Post #344781 27th Aug 2015 4:42pm
result! Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #344806 27th Aug 2015 7:12pm
mzplcg
Excellent result. And far better than Poly. I did a D3 with Polybushes back in 2008 and they were in there for a grand total of a month before I did them all again with genuine items. They absolutely ruined the ride.
Post #344844 28th Aug 2015 10:06am
