Home > Technical (L322) > Part Identification
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Part Identification
Hi, I had a water pump leak so decided after reading wiki to do it today, sounds so easy, lol.
After fabricating a tool to lock and remove viscous fan (free to be borrowed by anyone near Durham) I proceeded to remove water hoses at which point the elbow snapped off the top hose ! Ah well new hose needed.
Water pump fitted and decided to remove rest of top hose fittings this is where it got really interesting the small hose near oil cooler also snapped and a spring and valve flew out of the unit.
Well I am convinced this was plastic going brittle and not a case of sever sausage fingers !
Anyhow whats the correct name for the four way manifold affair alongside the oil cooler.
Many Thanks Mick
Post #344580 26th Aug 2015 6:19pm
johnboyairey
I think you are referring to the lower left of the rad area, looking down from above, the transmission fluid radiator. there is a smallish black plastic cover that has (as you describe) the junction of coolant hoses, and a clip or two to locate it onto the said mini-rad. it is available, but I cant tell you what its called. but you could search part numbers. using diagrams. (rave?) that's really the best direction. first the engine area, then water circuit, and then look for the part etc. and then the number.
I think I looked a while back and it was about £40, but I managed to find the clip that I had lost from it etc. yes those plastic parts go brittle.
advice: when replacing those hoses, don't slide out the snap rings push hose on and then slide them in .. leave them in, and coat the faces with a small amount of vasalene, and push them on and listen for the ring to snap closed. that way, you know its seated. otherwise, the hose itself, can push off and the coolant floods out.
Post #344584 26th Aug 2015 6:54pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Transmission Oil Cooler Thermostat - PBM000010
http://www.island-4x4.co.uk/thermostat-coo...-7083.html
I seem to remember it's twist lock or clipped together so it might just have popped out and can be put back together (looking at the photo there's a C-clip on the left hand end that holds the thermostat valve and spring in).
It attaches to the mounting plate or housing - PCU000140
http://www.island-4x4.co.uk/thermostat-coo...-7084.html
Post #344607 26th Aug 2015 8:37pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Pcu000140 mounting plate Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #344609 26th Aug 2015 8:44pm
mick-ne
Spot on Weejock that's the fella, one of the grooves for the clip is partly broken so cant trust it. best to fit new while its apart.. Thanks for the replies guys, Mick
Post #344615 26th Aug 2015 8:58pm
johnboyairey
Yep!
Post #344647 26th Aug 2015 11:47pm
