Home > Technical (L322) > MY2008 rear diff failure
BobbyDazzler007
2008 Range Rover Vogue SE TDV8 Buckingham Blue
Hi.
I've searched the forum but can't find out if this is a common problem.
Was suffering from vibration in the 'body' of the car (and now that I reflect on it, there has been some whine from the transmission).
The LR dealer has been great and diagnosed that the rear diff has failed and is causing the problem.
WarrantyWise are refusing to cover the cost of replacement, because it hasn't catastrophically failed, and its down to normal wear and tear. Their independent engineer has viewed the car and agrees that the diff is causing the problem.
I've got full LR service history, and 95k miles on the car. Mainly motorway driving, no offroad.
My question is, is this premature wear and tear failure - should the diff reasonably last longer than this.
Really p***ed with WarrantyWise, I think they just don't want to cover the cost.
Any help very gratefully received. Thanks
Post #202438 5th Aug 2013 12:35pm
Have they said they will cover it still if it fails soon though???
I'd be tempted to put some sand in there and run it for a bit Very Happy then flush it out, or drain it take the cover off and use a lump hammer and cold chisel...
Not saying any of this is a good idea mind Very Happy
TBH i haven't heard of any others but 1 failing which is documented somewhere on here but 1 in the many that are on here and with much higher miles is a sign its a rare failure.
Maybe best to go to an indy and get a 2nd hand unit fitted and get the fluis in the front and transfer box drained and refilled. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #202441 5th Aug 2013 12:59pm
I think now that it's on WWs radar, any subsequent catastrophic failure will be looked upon with some suspicion! Rolling Eyes Got - 2017 SDV8 Autobiography in Loire Blue
Post #202453 5th Aug 2013 1:19pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Hi land rover extended warranty also refuse to cover anything on mine regarding the rear diff or gearbox leak.
Spent a lot on wonderful LR engineering this month and last. Pretty Censored off myself to!
Post #202524 5th Aug 2013 9:14pm
Baltic Blue
Just for info, on the subject of rear diff failure.
I bought a brand new 2.5td P38 in January 2000, : rear diff failed in March 2000 less than 2000 miles.
Obviously changed under warranty. Did 100k+ with no further problems.
Post #344123 24th Aug 2015 1:16pm
It's not a common problem, however it is well documented on here that the rear diff oils require attention sooner than LR say as the can appear very dirty/rusty at quite low mileage.
Not heard of a diff failing through wear an tear. The front diff on earlier cars was problematic, but was fixed under Lr recall/warranty. If they are refusing to pay out (which doesn't supprise me in the slightest) then it is worth having yours rebuilt by a specialist which would give you more peace of mind than a used one, and come with a warranty. They can strip them and rebuild them replacing any worn parts. There is nothing that can't be fixed with a hammer😜😜
Post #344345 25th Aug 2015 4:33pm
miggit
If WW wont cover it then I'd look to a transmission specialist to get the diff re built, failing that good old fleabay for one off a breaker Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #344367 25th Aug 2015 6:56pm
