![]() | Home > Technical (L322) > MY2008 rear diff failure |
Have they said they will cover it still if it fails soon though???
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6770 ![]() ![]() ![]() |
I think now that it's on WWs radar, any subsequent catastrophic failure will be looked upon with some suspicion! |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Hi land rover extended warranty also refuse to cover anything on mine regarding the rear diff or gearbox leak.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Just for info, on the subject of rear diff failure.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
It's not a common problem, however it is well documented on here that the rear diff oils require attention sooner than LR say as the can appear very dirty/rusty at quite low mileage.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
If WW wont cover it then I'd look to a transmission specialist to get the diff re built, failing that good old fleabay for one off a breaker |
