Home > In Car Electronics (L322) > Td6 head unit and speakers
Steveo
Good morning am looking for help I got in my car to go to work this morning and the stereo didn't sound normal so I went to settings and fade full rear full front full left full right and found out that non of the front right speakers are working is there any thing to check and what's the best way to go about it cheers Steve
Post #343715 22nd Aug 2015 7:56am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
HI Stevo,
It may be a long shot , but try a battery disconnct (leads together) My radio played up a couple of months agao - (it wouldn't tun off)been ok since the disconnect.
cheers
RP
Post #343717 22nd Aug 2015 8:22am
I would look for bad connections on the two speaker plugs on the top of the DSP.
Try wiggling the plugs and see what happens.
Post #343719 22nd Aug 2015 8:39am
Steveo
Do I just need to remove the leather dash top
Post #343723 22nd Aug 2015 8:50am
Fortunately not, the DSP is the large black box standing vertically at the rear of the rear side compartment in the luggage space.
I had similar to you and it was a bad connection on the rear left plug (facing the box) on the top of the DSP.
Post #343724 22nd Aug 2015 8:57am
Steveo
Thanks you will have to excuse my stupidity is the dsp behind the cover near the reverse sensor control box cheers
Post #343726 22nd Aug 2015 9:09am
Nearside rear compartment. Thumbs Up
Post #343727 22nd Aug 2015 9:10am
mjdronfield
You could also remove and refit the big black plug from the BM54. It feeds the dsp. Left hand side of the boot, slightly further forwards and a bit lower than the dsp. Not the one with the blue and white connectors, that's the TV module.....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #343757 22nd Aug 2015 11:03am
Steveo
Thank you all its fixed now 😀😀😀
Post #343786 22nd Aug 2015 1:54pm
mjdronfield
What did you do ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #343805 22nd Aug 2015 4:20pm
Steveo
Un plug and re connect the box you said turn off ignition and back on hey presto all working cheers again
Post #343825 22nd Aug 2015 6:11pm
