Home > In Car Electronics (L322) > Td6 head unit and speakers |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
HI Stevo,
22nd Aug 2015 8:22am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
I would look for bad connections on the two speaker plugs on the top of the DSP.
22nd Aug 2015 8:39am |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
Do I just need to remove the leather dash top |
22nd Aug 2015 8:50am |
Fortunately not, the DSP is the large black box standing vertically at the rear of the rear side compartment in the luggage space.
22nd Aug 2015 8:57am |
Thanks you will have to excuse my stupidity is the dsp behind the cover near the reverse sensor control box cheers |
22nd Aug 2015 9:09am |
Nearside rear compartment. |
22nd Aug 2015 9:10am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
You could also remove and refit the big black plug from the BM54. It feeds the dsp. Left hand side of the boot, slightly further forwards and a bit lower than the dsp. Not the one with the blue and white connectors, that's the TV module.....
22nd Aug 2015 11:03am |
Thank you all its fixed now 😀😀😀 |
22nd Aug 2015 1:54pm |
What did you do ? 2011 Range Rover Vogue SE 4.4 TDV8
22nd Aug 2015 4:20pm |
Un plug and re connect the box you said turn off ignition and back on hey presto all working cheers again |
22nd Aug 2015 6:11pm |
