Home > Maintenance & Mods (L322) > HVAC 'Aspirator' Fan |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Can't answer your question, but can tell you my FFRR has had the aspirator fan fault since I was able to read codes @ 6 years ago, my air con works fine, though.
21st Aug 2015 4:44pm |
MrKev Member Since: 09 Aug 2015 Location: UK Posts: 22 |
Thanks Joe, Yeah, I will do, I'm just going through the various bits and bobs I can tinker with, like the the electric seats - now fixed. I though I'd have a go at the 'fan' problem, as it was an error code, but it's useful to know that it should run as is, which means electrically it should be working for an a/c technician to diagnose the fault.
21st Aug 2015 4:49pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8257 |
What diagnostics are you using, some will show pressure which will give you an indication if it is just low on refrigerant or has a leak.... The two most common reasons not to be cool.... Pete
21st Aug 2015 5:16pm |
I've had the pressure tested by an a/c guy, and it's normal, but knowing there was a diagnostics fault recorded on the fan, didn't pay for full teardown of the a/c system in case it was as simple as fluff in the fan.
21st Aug 2015 5:19pm |
Oh right... for your info the aspirator fan is the small fan that sucks air in through the little grille on the front of the heater control panel, but as Joe says his works with the same fault so probably nothing to do with it, a proper code read or studying the live data should point you in the right direction.... Pete
21st Aug 2015 5:33pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I've got a couple of hvac control unit/switch panels from when I was fault finding my ac system, let me know if you need one. |
21st Aug 2015 5:45pm |
@Haylands: yeah, except there's no fan in there.
21st Aug 2015 6:43pm |
