Home > Maintenance & Mods (L322) > TRANSFER CASE AND differential fill/drain washers |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Here is a picture of the transfer case mud I mean oil. 120k miles.
13th Aug 2015 12:47am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
It's obviously not ideal to re-use but if you're stuck and surfaces are OK and the washer isn't scored or harden then it's not a real issue although no doubt some will think it's a huge taboo to do. Typically though, copper washers go hard after a time.
13th Aug 2015 1:40am |
Thanks Weejock that makes sense why they say replace washer. I had though that maybe they were more like spark plug crush washers. Good info on restoring their pliability. |
13th Aug 2015 2:17am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
It's not ideal but you can flip the washer over if it's only been used once. |
13th Aug 2015 3:24am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8283 |
A new one is just hogwash, I've never bothered with a new one, been servicing cars for over 30 years, never had one leak... the only time they leak is when they are over tightened and damaged... Don't do them up to the ridiculous torque they specify either, it's usually far too high, just nip them up and then a tad more.... Pete
13th Aug 2015 10:47am |
I'm not so sure, i mean i agree using a new one every time is probably over kill. But i have seen plenty of sump washers on minis that were leaking like hell because they'd clearly never been replaced.
13th Aug 2015 11:33am |
Thanks all for the input. I know I have reused engine oil drain washers in the past without issue but now I know why they tell you use a fresh one. My Jaguar/RR dealer is about as small as they get. Maybe 6 people run the entire place. Parts guy asked me if the 2004 HSE was a full sized RR. When I met him I got the impression he wasn't an enthusiasts. I don't know if this is a RR dealer standard practice but they don't keep trade-ins to sell used. Only sell loaner cars as used. This could partially explain why he didn't have a clue about older RR models. |
13th Aug 2015 1:16pm |
Did the rear differential today. Came out as clear as the new stuff. |
18th Aug 2015 6:35pm |
