Home > Maintenance & Mods (L322) > TRANSFER CASE AND differential fill/drain washers
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Here is a picture of the transfer case mud I mean oil. 120k miles.
Anyone reuse the copper washers? Can't see an issue if the surfaces are clean. My local dealer can't find a part number without a VIN. Didn't have it with me.
Post #342171 13th Aug 2015 12:47am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
It's obviously not ideal to re-use but if you're stuck and surfaces are OK and the washer isn't scored or harden then it's not a real issue although no doubt some will think it's a huge taboo to do. Typically though, copper washers go hard after a time.
You can anneal a hard copper washer to make it softer so it seals like a new washer. To anneal it you heat the washer in a butane/propane torch until it turns a bright red colour, then let it cool off slowly. Sometimes I've even annealed new washers that have been sat around on store room shelves for ages and have gone hard.
Obviously check for leaks after a few miles whatever you do.
Post #342175 13th Aug 2015 1:40am
doclees
Thanks Weejock that makes sense why they say replace washer. I had though that maybe they were more like spark plug crush washers. Good info on restoring their pliability.
Post #342178 13th Aug 2015 2:17am
Zirconblue
It's not ideal but you can flip the washer over if it's only been used once.
Post #342180 13th Aug 2015 3:24am
A new one is just hogwash, I've never bothered with a new one, been servicing cars for over 30 years, never had one leak... the only time they leak is when they are over tightened and damaged... Don't do them up to the ridiculous torque they specify either, it's usually far too high, just nip them up and then a tad more.... Thumbs Up Thumbs Up Pete
Post #342217 13th Aug 2015 10:47am
Zirconblue
I'm not so sure, i mean i agree using a new one every time is probably over kill. But i have seen plenty of sump washers on minis that were leaking like hell because they'd clearly never been replaced.
I reckon you can probably get two or 3 uses out of them safely by flipping them over, but after that they start to get a bit thin. I think the only reason service procedures specify new ones, is they're written on the side of caution as the washer could have been used countless times already and it's not worth risking a leak for a 20p washer.
A parts guy who claims he can't get a part number without a vin is just someone who doesn't know what he's doing. I've just found IYF500010 for the transfer case in a bout 2 min, it's the same on all L322's.
Rear diff is RYF000050 and RYX000020 for pre-2006 model year. And after that it doesn't look like they have a sealing washer just a plug (which might have a rubber seal bonded into it like the gearbox bungs)
The front diff doesn't have seals you just apply sealant to the threads.
I've just looked them up here.. http://cat.lrparts.ru/
Post #342229 13th Aug 2015 11:33am
doclees
Thanks all for the input. I know I have reused engine oil drain washers in the past without issue but now I know why they tell you use a fresh one. My Jaguar/RR dealer is about as small as they get. Maybe 6 people run the entire place. Parts guy asked me if the 2004 HSE was a full sized RR. When I met him I got the impression he wasn't an enthusiasts. I don't know if this is a RR dealer standard practice but they don't keep trade-ins to sell used. Only sell loaner cars as used. This could partially explain why he didn't have a clue about older RR models.
Post #342239 13th Aug 2015 1:16pm
doclees
Did the rear differential today. Came out as clear as the new stuff.
Post #343140 18th Aug 2015 6:35pm
