![]() | Home > Maintenance & Mods (L322) > Lower Control Arms Changed |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
Hi all,
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3894 ![]() ![]() ![]() |
I already had the passengers side done just before I sold you the car, so I suppose drivers side was only a matter of time. Geoff |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8528 ![]() ![]() ![]() |
Check with the garage that they tightened the bolts from arm to subframe with the car on the ground at standard height, if they did it on a lift and tightened them with the wheels hanging then the bushes will be wound up and can give a harsh ride... Pete
Thanks guys. I'll check with the garage tomorrow then maybe look at wheel alignment,
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It depends what they have, most tyre places just have a basic 2 wheel laser alignment system.
I've not spoken to the garage today but noticed that the car seems to be a little off level when parked at work. At first I,just thought it was the way I had parked but I looked on the info screen and the level indicators looked out of line and when driving they seemed to keep changing. I plugged my iid in all 4 wheels had different settings. I've balanced them out and it looks and feels a bit better now but still not as I remember it. |
The wheels should have different settings, no two sensors are the same... Did you do the levelling as per GAP's instructions?? Pete
Sorry Haylands, I forgot to thank you for the tip |
No problem mate, glad you got it sorted... have you found out if they did the final nut tighten on the ground??? Pete
I'm going to call in and see them today. |
I finally got this checked as the car needed another service, 2nd in 6 months |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
Just a bit of advice for the future, all bushes that a symmetrical should be changed in pairs. |
