![]() | Home > Technical (L322) > FBH Remote Issues |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Tried to sync the existing remote but no joy, therefore purchased a newer style remote from Ebay which was listed as new but gone through the sync process but still no joy.
Thanks, looks like I got the wrong one - at least I didn't pay a lot for it. Regards
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Those L405 ones are £250 from Land-Rover!
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Try replacing the battery in your existing remote, sometimes an older battery doesn't have the juice left to send a clear sync signal through to the receiver.
Thanks - that was this first thing that i did |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Is it definitely a problem with the remote - does the heater work OK when switched on manually ?
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 ![]() ![]() ![]() |
Think you are right Alistair - the temp has to be at 6 deg C or less before the thing will start if my memory serves me.. Range Rover Vogue SE SDV8 - L405 (now sadly sold)
You can also use the Remote to turn on the fans for ventilation/cooling when the temperature is higher than 6 Degrees. The LED on the remote shows green for ventilation and red for the FBH.
Works fine from the touchscreen
Proser i have a spare one if you want to pop up this weekend and try pairing it up?
Just to clarify here, I don't think there is an issue with the T90/T91 fobs.
they changed to a different webasto setup i believe at that point. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Kingpleb - whereabouts are you ?? Regards
