Home > Technical (L322) > FBH Remote Issues |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Tried to sync the existing remote but no joy, therefore purchased a newer style remote from Ebay which was listed as new but gone through the sync process but still no joy.
13th Aug 2015 1:54pm |
Thanks, looks like I got the wrong one - at least I didn't pay a lot for it. Regards
13th Aug 2015 2:47pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Those L405 ones are £250 from Land-Rover!
13th Aug 2015 2:53pm |
will do the same as only paid £14 for mine Regards
13th Aug 2015 2:54pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Try replacing the battery in your existing remote, sometimes an older battery doesn't have the juice left to send a clear sync signal through to the receiver.
14th Aug 2015 9:44am |
Thanks - that was this first thing that i did Regards
14th Aug 2015 9:55am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
Is it definitely a problem with the remote - does the heater work OK when switched on manually ?
14th Aug 2015 9:58am |
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 |
Think you are right Alistair - the temp has to be at 6 deg C or less before the thing will start if my memory serves me.. Range Rover Vogue SE SDV8 - L405 (now sadly sold)
14th Aug 2015 10:31am |
You can also use the Remote to turn on the fans for ventilation/cooling when the temperature is higher than 6 Degrees. The LED on the remote shows green for ventilation and red for the FBH.
14th Aug 2015 11:09am |
Works fine from the touchscreen
14th Aug 2015 11:14am |
Proser i have a spare one if you want to pop up this weekend and try pairing it up?
14th Aug 2015 12:49pm |
Just to clarify here, I don't think there is an issue with the T90/T91 fobs.
14th Aug 2015 12:56pm |
they changed to a different webasto setup i believe at that point. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
14th Aug 2015 12:59pm |
Kingpleb - whereabouts are you ?? Regards
