![]() | Home > Off Topic > Outdoor Swimming Pool |
Does anyone have any knowledge or information on the upkeep of an outdoor swimming pool are they costly to maintain , hard , easy to look after .This will be be on a property on the Costa Del Sol area .
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I've got one (8m x 4m) in my Costa Blanca villa. What do you need to know? Graham
Mostly if they are expensive to maintain , how often do they need cleaned , guessing it will have to be done by a company that specialises in pool cleaning and what do they charge as I won't be over in it much more the wife , daughters and such . Are they worth the bother .
Hi
Cheers Graham |
If you do the tube heating maybe worth sticking some panels up for the pumps as well possibly and a small battery bank? Bigger up front cost but something that will again save in the long run...
Where we are just now we are only 5 minutes from the beach , it was mostly just to find out costings if we went to a Villa with its own pool |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 ![]() ![]() ![]() |
@ kingpleb, Do you mean panels and battery bank for the filtration pump? They are 230V - mine is. John
Yes, you can i believe get lower volted pumps or use a transformer if needed but solar power is a good idea to have on the roofs in a sunnier climate anyway |
Salt water pools are much nicer to swim in than chlorine and the chlorinator for units these day draw much less power . You need to run your pump and chlorinator for about 4 hours each day in winter and 8 in summer so seeing as it's a second home have your pump and filter somewhere nice and safe just in case something goes really wrong in your absence and anyway the further the quieter . I look after my own pool so i have all the chemicals but you will use a service so it's something less to worry about . Solar heating is essential but I always bitch that it works best when you least need it and a good cover saves a lot of work . 2008 MY Supercharged
