Home > Technical (L322) > heavy steering started |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35422 |
i had the servotronic valve go on my td6 Matt and the symptoms were as you describe..
12th Aug 2015 11:47am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^^ I'd look at that pesky servotronic valve thingy, or cancel your gym membership as you is going to get a free workout ffrr styley Yesterday I couldn't spell Engineer... Today I are one!
12th Aug 2015 12:12pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Stan, Matt face lifted his early model 4.4 V8 Petrol car to 2012 spec so his is an early model NOT a 2012 as per his details...
12th Aug 2015 12:45pm |
thats what i thought Craig but the little car says 2012. ... - .- -.
12th Aug 2015 1:13pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2660 |
I have a valve still for sale |
12th Aug 2015 2:06pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Dam only just seen this, have ordered one from Dan |
12th Aug 2015 4:36pm |
Did some more testing this afternoon before ordering the servo valve, I monitored the servotronic PWM % on my faultmate to see if I could see anything and with the engine off I got various readings and when I started the engine I got various reading however after about 5 seconds the value dropped to 0% coninusilly so I'm hoping this indicates is faulty. I also removed the drivers front wheel and checked the valve wiring for damage and all looked good in fact the connector looked in brand new condition.
12th Aug 2015 4:44pm |
Bu66er , think I'm way cheaper than Dan ! Hope it fixes the problem. |
12th Aug 2015 8:51pm |
Just replaced the BCM for a brand new one and the heavy steering issue has gone, everything is working perfectly and the steering feels better than ever!
25th Aug 2015 2:06pm |
So was it the valve as well, or just the on set of dementia in the BCM? Yesterday I couldn't spell Engineer... Today I are one!
25th Aug 2015 4:28pm |
My issue was just with the BCM being faulty, the valve that I removed was in perfect working order. I have kept the new valve on as the old one was 12 years old.
25th Aug 2015 6:29pm |
