![]() | Home > Maintenance & Mods (L322) > Brake Squeel and low level hum and low speed braking |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Hi all,
No replies? I take it that my issue is rare?
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Could be cheap pads, but Have you allowed the new pads and discs to bed in? |
On the last set of discs and pads I've done about 300 miles so far - should be bedded in? CURRENT : FFRR 2012 4.4 TDV8
Depends how you've been braking. If you've been braking hard from day one it won't have done them any good. |
No I've been kind on the discs every time I have a new set out on - always feathering when coming to a stop . Think I've done everything as requested by the garage but I am erring on the side of inferior pads at the moment - any recommendations for pad manufacturers? CURRENT : FFRR 2012 4.4 TDV8
Pagid's from Euro car parts are fine, reasonably priced too, mine has them at the moment.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
I'd still be tempted to try adding a leading / trailing chamfer to see if it makes any difference.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
you might struggle to get any front non OE/gen discs for the 4.4tdv8, i was just looking and the only available ones i could find were gen in any case, so i would doubt the discs are the problem.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
My 2p’s worth, ONLY use Gen pads in the front! OE disks will work but my findings (the same as with 3.6’s) ONLY genuine JLR pads work without noises! |
Lego Member Since: 01 Jul 2015 Location: Suffolk Posts: 12 ![]() ![]() ![]() |
Air in the brake lines? My 04 TD6 squealed like a good un when I bought it. I changed the front discs and pads but to be honest those I took off were fine, I did get horrible old brake fluid out when I bled the brakes but also found the brake dust shields on the inside of the discs had rotted around two of the attachment bolts (3 in total) which would have caused them to resonate, anyway penny washers sorted that problem both sides. No more squealing, however just this past week have now picked up a low speed squeal from the drivers side rear mainly on light braking and low speed turning (in the drive through at Mc D's for morning coffee) it seemed noisier this morning and that particular alloy had a greater deposit of brake dust than the other 3 with a slight whiff of hot brakes from that rear wheel area. The disc and pads on this rear wheel are fine so I'm suspecting that the piston is maybe not retracting the pads due to air in the caliper/rear brake system or I have too much play in the rear bearing allowing the disc to contact the pads at low speed before it pushes them away or allows the pads to ride the disc (increased brake dust). Cheapest option first I'll be bleeding the brakes this evening.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Squeals from brakes are mostly due to the pads vibrating in the caliper. There could be other issues as RiccartonRR mentions but on a 2012 model I would hope the pistons are still in good condition and moving freely, worth checking though and you would hope the garage did.
For myself it wasn't a cheap bleed the rear brakes fix I'm afraid,
New calipers, discs and pads have sorted the squeal and I also found one of the height sensors on the rear had split rubber around the lower attachment bolt which allowed about 10mm of movement in the feedback arm. A small jubilee clip sorted this as a temp repair and lo and behold my vehicle has leveled itself which previously had a slightly nose high attitude which had me pondering spending 300 notes on a suspension reset tool. Moral of the story always check all visable parts when the wheels are off!
