Home > Maintenance & Mods (L322) > Dash facia control dials
J90
France 2006 Range Rover Vogue Td6 Java Black
I've noticed that the dash facia dials on the 2007>RR are edged in silver/chrome. Can these be used to replace the boring all black ones on the 2006 TD6 dash facia. Can the all black ones be 'pulled off' and replaced with the smarter chrome edged ones.
If they can, are they something you can buy as individual spare parts or do you have to source a dash panel to cannibalise?
Ta.
Post #340898 5th Aug 2015 6:59pm
Zirconblue
I think the knobs are an integral part of the panel as they have a push button in the middle of them.
However i don't see why the complete panel couldn't be swapped for a later one, as they're the same, just different cosmetics.
I think you'll be stuck with the clock and suspension switch though, as they moved the suspension switch on later ones.
Post #340913 5th Aug 2015 7:56pm
mjdronfield
I believe this has been covered a number of times on here.
General consensus is that the units are not interchangeable, but some have managed to build the facia from 2 units......or do some machining.....
http://www.fullfatrr.com/forum/topic27186.html?highlight=knob
http://www.fullfatrr.com/forum/topic23702.html?highlight=knob
http://www.fullfatrr.com/forum/topic15232.html?highlight=knob
http://www.fullfatrr.com/forum/topic11379.html?highlight=knob
Etc
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #340917 5th Aug 2015 8:07pm
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Did my 2002td6 and posted the results on here .
I have a completed 2010 unit for sale that you can strip down for the parts .
It is fairly straight forward to do takes less than an hour to do .
If you can't find the pics I will take some more and post them
Looks like its the first link above Thumbs Up
Post #340923 5th Aug 2015 8:21pm
Zirconblue
Aren't the 2007-2009 heater panels interchangeable with the earlier ones? They look like the same panel, just with different knobs on.
The 2009 onwards one is completely different though.
Post #340935 5th Aug 2015 10:06pm
J90
Thanks guys. Thumbs Up
Post #340937 5th Aug 2015 10:22pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
yes you can use the later heater 2007-2009 control panels on earlier cars they are the same units just with slightly different buttons. i bought a 2007/8 panel from a diesel and then just swapped over the grey fascia as the earlier one is slightly lighter than the 2007+ and then reprogrammed it to my car and options, worked a treat all the connections are identical
hope this help
Matt
Post #341293 8th Aug 2015 3:44pm
