Home > Maintenance & Mods (L322) > Battery replacement, tight fit
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Who ever had my ff before me had replaced the battery and as the new one was to big had balanced it on a bit of wood , this resulted in movement and the positive lead coming loose this then caused the positive battery terminal to partially melt meaning the positive lead would not tighten up on the terminal , I also started getting the usual bundle of warning lights , and a couple of times the car wouldn't start til the positive lead was wiggled a bit , so today I finally got round to sorting it , first new battery Bosch s5 110A /920A ( £125 from Eurocp) . Then I manufactured a wooden bracket to sit the battery on with clamps to hold it in place. See the photos you'll get the idea , just thought I'd post this in case anyone else has the same bother.
Post #340586 3rd Aug 2015 3:54pm
trimming the bottom lip of the lower passenger side edge will make it fit perfectly, might void the battery warranty though......
did that on my 3.6, as i couldn't get it in no matter how hard i tried Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #340646 3rd Aug 2015 9:15pm
birchyman71
I tried trimming the bottom lip off it was still about 5 mm to big , also tried loosening the battery tray off and moving it , so had to resort to what you see. What I will do is extend the cabling and change the connection to allow the battery to sit in the tray properly but I had nothing suitable in the garage so will look into that when I'm back at work
Post #340676 3rd Aug 2015 10:42pm
What is wrong with a correctly sized JLR battery sir? I ask as that seems like A, a lot of work B, questionable MOT standard & Finally C, the Bosch S5’s fail for a past time (well documented on here)
Post #340679 3rd Aug 2015 11:43pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
WHY
the original fit is perfect
never had any issues with a loose battery
Post #340705 4th Aug 2015 10:23am
Zirconblue
The Bosch ones are about £100 cheaper than the Genuine ones, would be one reason i suppose.
YDG000271 is the part number for the Land-Rover 110amp battery.
I think the genuine batteries are made by Exide or Varta depending on where they sourced them from on a given day.
Why do you have an 015 though? ECP list an 017 (90amp) and the 020 (110amp)
Post #340726 4th Aug 2015 1:48pm
mzplcg
Hmmmm, inventive enough. Think I'd have bought the genuine thing complete with any missing mount brackets TBH.
Post #340734 4th Aug 2015 2:11pm
