Home > Group Buys > IID Tool - Bluetooth - £365 delivered
Mikey
Currently being run on D3. We have our minimum of 10 units, if anyone on this side is interested
Not huge savings, but better than nothing Thumbs Up
http://disco3.co.uk/forum/topic130337.html
Post #331649 9th Jun 2015 11:41am
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Does anyone here know Mikey? I ordered and paid for one of these 6 weeks ago and it's still not been delivered and there is no reply to posts or pm's. I'm getting a little Censored off now Mad
Post #340507 3rd Aug 2015 8:04am
Lost for Words
If anyone is interested, Mikey's running another GB the same again: http://www.disco3.co.uk/forum/topic133849.html Thumbs Up
(Just to mention, Fish has now received his IID. Wink ) Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #345087 30th Aug 2015 8:13am
Lost for Words
Minimum of 10 already met now, but more are still welcome. Smile
Thumbs Up Visiting from DISCO3.CO.UK
Post #345253 31st Aug 2015 9:56am
Mikey
Issues were had with Royal Mail and delivery to Fish, and subsequent return to myself.
As above though, we are now at 10 units, the more the merrier Thumbs Up
Post #345265 31st Aug 2015 10:49am
Mikey
A bit more info, for anyone sitting on the fence Wink
You can get details of coverage here: http://www.gap-diagnostic.com/products/iidtool.html
For the BT model, the basic functions (fault codes, live data, component control and service routines) are unlocked and available for all covered vehicles. Enhanced functions (CCF editing and ECU flashing, and calibrations like the suspension, transfer box and SAS) are VIN locked. You can buy additional licences (for any covered model) for £60.
The device works best via bluetooth using an app (free - Android and Apple), allowing graphing of live values etc., but can also function on it's own using the instrument cluster to write on like the IID "classic". (NB: Not all Android devices are compatible, so best to check first.)
Having worked my way through various diagnostic tools over the years (IDS/SDD, Autologic, Faultmate, Haweye, Nanocom etc), the IID Tool beats them all hands down, for ease of use, accessibility, info provided, and above all else, price...
The IID Bluetooth unit is exactly the same as the IIDPro which I use on a daily basis, but is VIN-locked, as explained in the above. The only difference is the Pro version is VIN-Free, and the price.
The IID will perform functions that even JLR's own SDD diagnostic system cannot do, such as Sat Nav on the Move (allows you to enter destination while driving)
It allows FULL Car Configuration File (CCF) editing and allows you to unlock "hidden" features within the car
It allows full software updates (not all models are currently covered, but they are in the pipeline), some of which as required for CCF editing and features to work, such as 3 Flash Indicators.
It allows EAS calibration, either individual corners, front only, rear only, or all 4 corners.
And if it all goes wrong with a calibration, or CCF editing, there is a Restore function, to put it back to standard Thumbs Up
There has been much thought and care put into each, and every process the IID Tool can perform.
They even go as far as forcing failed software updates, and have recovery processes already in place. Most of which goes on in the background automatically, so the end user doesn't have to do anything
I have taken some screenshots with my own Disco 3. There will be differences between the models, and some features available on some that are not there on others.
Fault Code read/Clear
You can also email them to yourself for future reference, or easy copy/paste. The forum software sees 8 + ) together as Cool Whistle
Quote:
VIN: SALLAAA135A336942
Vehicle scanned on 31-08-2015 13:30
Using IIDTool Pro V3.0 B2520
Auxilary Heater
U1A44-6C (2E) Fuel level
Body Control
B1B56-87 (2Cool Sliding roof module - Bus signal/message failure - missing a message
( at 167136 mi )
B1B70-81 (2Cool Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( at 166925 mi )
B1C82-14 (2F) Headlamp washer relay coil circuit - General electrical failure - circuit short to ground or open
( at 166900 mi )
B1C90-14 (6C) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to ground or open
( at 166900 mi )
B1C95-15 (2E) Approach lamps circuit - General electrical failure - circuit short to battery or open
( at 166918 mi )
B1D12-15 (2E) Volumetric alarm power circuit - General electrical failure - circuit short to battery or open
( at 166918 mi )
B1D13-15 (6Cool Interior lamps 1 circuit - General electrical failure - circuit short to battery or open
( at 167117 mi )
B1D14-15 (6Cool Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
( at 167826 mi )
B1D17-87 (2F) Siren Circuit - Bus signal/message failure - missing a message
( at 166900 mi )
B1D18-87 (2F) Volumetric sensor circuit - Bus signal/message failure - missing a message
( at 166918 mi )
Engine TDV6
P0405-00 (2D) Exhaust gas recirculation sensor A - circuit low
P140A-00 (2D) Exhaust gas recirculation sensor C - circuit low
Parking Aid
B1B48-96 (6Cool Rear left outer sensor - Component failure - internal failure
Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
Ventilation
B1B65-15 (6C) Left seat heater temperature sensor - General electrical failure - circuit short to battery or open
B1B66-15 (6C) Right seat heater temperature sensor - General electrical failure - circuit short to battery or open
( at 166904 mi )
B1B75-00 (6Cool Front foot-face mode stepper actuator
( at 167827 mi )
B1B76-00 (6Cool Front left air blend stepper actuator
( at 167827 mi )
B1B77-00 (6Cool Front right air blend stepper actuator
( at 167827 mi )
Height Calibration
Module/Sensor/Height calibrations
Service/Test Menu, offering Key Programming, Service Interval Reset, Aux Heater prime and Operation Check, EPB Unjam function, Lift Pump Security Reset, Suspension valve testing, and Transmission Adaptive Reset
It offers Live Values, both in digital, and graph form
The graphs are invaluable for pinpointing intermittent faults, as you can see the specific rise/fall in readings, instead of the digital values
It offers "Safe" CCF Editing
PatGAPinnov wrote:
Just a few little corrections since Mike does have a Pro and not a BT:
-For safety reasons, access to the full CCF list is available upon request only. However, the tested settings are available to all and these cover 99 % of all requirements.
It also offers "Advanced" editing. For 99% of owners, this option will go unused, but it can be made available for anything you want to retro-fit, or enable. This is where the CCF Restore function is invaluable Bow down
-Re-flash wise, the Pro is capable of housing all supported files while the BT does require either updating the tool to a special firmware for the Nav On Move or using the PC based interface for updating the Bluetooth in any other languages then UK English.
For more details on which re-flash are available and the fast lane service, please have a look at the user manual: http://www.gap-diagnostic.com/support/documents.html
ECU Flash screen. All of these Firmware options are free to use. There is a small charge for Firmware not listed in this menu, and is supplied direct from GAP.
The ECU Info tab allows you to see modules which are fitted to the car and what firmware is currently installed. Invaluable if you are having module communication issues
The Save/Restore tab allows you to save your specified height requirements, and change to them in a matter of seconds, as well as the CCF Restore, just in case Wink
Considering a main dealer will generally charge a minimum of £100 for a diagnostic plug in, the IIDTool offers excellent value for money, and while the saving is not huge, its better than nothing Thumbs Up
Post #345301 31st Aug 2015 1:24pm
Lost for Words
Bump. Few days left for those undecided. Closes on Sunday. Thumbs Up Visiting from DISCO3.CO.UK
Post #346051 4th Sep 2015 10:49am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
if i wanted one would i have to specify its for a 2003 L322 or are they all the same and how would i pay
cheers nige
Post #346072 4th Sep 2015 12:18pm
Lost for Words
No, the BT model is the same for all vehicles. The part number may/will not be intended for the L322, but they all run the same firmware and can be unlocked for any of the covered vehicles. Thumbs Up
You'd have to speak to Mike about payment, but I assume he's going to send details out once everyone's signed up.
Post #346077 4th Sep 2015 12:36pm
ironhorse
ok cheers
Post #346081 4th Sep 2015 12:45pm
Lost for Words
Last chance to sign up for one of these excellent tools. Thumbs Up Visiting from DISCO3.CO.UK
Post #346354 6th Sep 2015 11:42am
Mikey
As it stands, we have 17 signed up, so the buy will be going ahead
It will close at midnight, so still a few hours to sign up Thumbs Up
Post #346368 6th Sep 2015 1:05pm
