Home > Technical (L322) > Help now super locked
Ziggy
Australia
Well here we are again got into the rangie, thanks guys. But now its super locked so even though were in the car
we cant open any doors or start the dam thing Censored Censored Big Cry Big Cry Rolling with laughter Rolling with laughter
Any ideas
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #339677 29th Jul 2015 8:17am
iKushtyy
England 2007 Range Rover Vogue TDV8 Stornoway Grey
Are you absolutely sure the battery has charge and is properly connected? Does the radio turn on? Key hasn't got wet or anything? Does the key turn off the steering lock when you put it on the ignition?
If you've managed to get in, I'd say now go change the battery, see if it makes the difference..
Edit: Just re-read the OP, you say you've got in, but can't open any doors.. So you're in the car, but the doors still super locked? If you're in, Pop the hood, disconnect the battery, then get hold of a donor battery and leads, or a boost pack, and try this:
http://www.rangerovers.net/forum/6-range-r...pics/38786
If the above energises the car, and the key works, you're battery is FUBAR.. If not, I'd suspect a new key..
Post #339680 29th Jul 2015 8:27am
Ziggy
Australia
Battery has 12.8 v
Key does diddley squat.......wont turn in the ignition so no radio no idiot lights all doors locked
George Santayana
Post #339694 29th Jul 2015 9:50am
mzplcg
Zig, if you can get to the battery I would go for a disconnect and let all the modules discharge (internal capacitors etc) so leave for 15 mins. Then re-connect and try again.
Dom
Post #339695 29th Jul 2015 9:54am
iKushtyy
Measured with a voltmeter off the starter, I presume? Although, just because it says that............ Now you're in, pop the hood and measure off the battery itself.. To rule it out, I'd still say swap it anyway, you know what these cars are like when it comes to voltage drop, they go and throw a huge hissy fit..
You can still turn radio on, just press the I/O button..
Nono, don't worry about turning the key, just does it turn off the steering lock when you insert the key?
Edit: Might be some useful stuff here:
http://www.rangerovers.net/forum/6-range-r...532?page=1
Other than that, if the battery is good, it's time for a new battery for the key.. It is a 13 year old RR, all batteries eventually fail..
Post #339696 29th Jul 2015 9:59am
You could try moving the gear selector lever back and forth a few times just in case the gearbox inhibitor switch is out of position and then try again with the key. I presume the key casing is intact?
Post #339706 29th Jul 2015 11:05am
mjdronfield
Don't think you can move the gear lever without the key in and the steering lock off. The key sends a signal to a relay I believe that energises the steering and key lock in the ignition lock, so I'm guessing it's not doing that. Are we sure the battery in the actual key fob is good ?
Can you get your spare key from home to the car somehow ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #339740 29th Jul 2015 4:11pm
^ Agreed Thumbs Up Senior moment Rolling Eyes
Post #339746 29th Jul 2015 4:39pm
You can get it out of park by removing the gearstick surround, it just pulls off, and lifting a metal bar that runs down the right side of the stick, this locks it in park....
The battery in the key could be flat but that won't make it not start... it has nothing to do with the immobiliser...
It sounds to me like you have a poor connection on the car battery, or the battery is flat... open the bonnet and connect some jump leads or something... check if the lights come on or the hazards... if they do and the key still won't work remove fuse 18 for 30secs and then replace, this will reset the immobiliser...
Once the ignition is on the lock button in the middle by the hazards should unlock the doors...
The only other thing I can think of is, has the key been dropped or taken apart and you have lost the transponder out of it, it is only a small lump of plastic and is loose in the key....
The symptoms you are describing are pointing towards a fault with the car and not the key though... just check and recheck it has power, and check all connectors... Pete
Post #339783 29th Jul 2015 7:52pm
Ziggy
Australia
Thanks to you all for your suggestions and help it off to the dealers tomorrow
we gave up, doors still all locked, still wont start, Censored Censored
after this experience I have decided to put one of my old classics back on the road
moving all the goodies over from the rusty one......
George Santayana
Post #339873 30th Jul 2015 8:18am
