Home > Technical (L322) > Help now super locked |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 |
Are you absolutely sure the battery has charge and is properly connected? Does the radio turn on? Key hasn't got wet or anything? Does the key turn off the steering lock when you put it on the ignition?
29th Jul 2015 8:27am |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Battery has 12.8 v
29th Jul 2015 9:50am |
Zig, if you can get to the battery I would go for a disconnect and let all the modules discharge (internal capacitors etc) so leave for 15 mins. Then re-connect and try again.
29th Jul 2015 9:54am |
Measured with a voltmeter off the starter, I presume? Although, just because it says that............ Now you're in, pop the hood and measure off the battery itself.. To rule it out, I'd still say swap it anyway, you know what these cars are like when it comes to voltage drop, they go and throw a huge hissy fit..
29th Jul 2015 9:59am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
You could try moving the gear selector lever back and forth a few times just in case the gearbox inhibitor switch is out of position and then try again with the key. I presume the key casing is intact? |
29th Jul 2015 11:05am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
Don't think you can move the gear lever without the key in and the steering lock off. The key sends a signal to a relay I believe that energises the steering and key lock in the ignition lock, so I'm guessing it's not doing that. Are we sure the battery in the actual key fob is good ?
29th Jul 2015 4:11pm |
^ Agreed Senior moment |
29th Jul 2015 4:39pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8206 |
You can get it out of park by removing the gearstick surround, it just pulls off, and lifting a metal bar that runs down the right side of the stick, this locks it in park....
29th Jul 2015 7:52pm |
Thanks to you all for your suggestions and help it off to the dealers tomorrow
30th Jul 2015 8:18am |
