Home > Maintenance & Mods (L322) > Rear upper tailgate swap over how to??
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hi I managed to get a new upper tailgate for my car as the current one is rusty. Is swapping it over a job I can do at home? If so how hard is it to do? Thanks
Post #339570 28th Jul 2015 4:07pm
Zirconblue
I've not done it, but from looking at it it's not especially difficult. The biggest problem is going to be supporting the old one while you remove the fixings, then supporting the new one when you refit the fixings.
I reckon you're going to want at least 2 strong mates to hold it, and i would think they're going to want hop ups or something to stand on. Unless you happen to know a basket ball team.
Post #339574 28th Jul 2015 4:34pm
JPS
Thanks for the reply, I was concerned about the wiring, do you know if it's easy enough to connect back up to the loom etc? Guessing it will just be for rear camera, wiper and lock etc.
Post #339683 29th Jul 2015 9:03am
Zirconblue
I'd have to look at RAVE, but I'm sure someone else will correct me.
I would expect there is a multiplug or two just under the rear of the head lining or behind the plastic trim at the top of the tailgate. As I said though, I would think if you can support it to remove and refit it you've got 80% of the job cracked.
Post #339685 29th Jul 2015 9:26am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Unless you have a secondhand tailgate, I suspect your biggest problem will be swapping the wiring loom over into the new tailgate.
I need to do mine and i recall reading something to this effect, if I can find it, I will post a link.
If you do crack on and replace it, a write up and some photos would be much appreciated! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #339720 29th Jul 2015 12:46pm
Zirconblue
Even that's fairly easy with some cable draw rods. I think screwfix do them for about £15.
Post #339725 29th Jul 2015 12:58pm
mzplcg
Wickes do net curtain flex for a quid. Does the job fine.
I didn't do mine myself but I did see some of it being done. The cables are removed from the old tailgate before the tailgate is removed and then taped up on the roof. Then the tailgate is changed over, the accessories refitted (Wiper motor, camera etc) and the wires are drawn back through the new tailgate using a pull cord. Fiddly but only took the guy about 10 minutes.
Final alignment of the tailgate was done after it was fully re-assembled.
Post #339727 29th Jul 2015 1:26pm
