![]() | Home > General > OH S**T !!! |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Not the Mrs is it? |
It could be many things from a worn diff to a wheel bearing |
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 ![]() ![]() |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Whine or aero sound?
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
Its a noise like a wheel bearing but it didnt go when turning etc, then i did think it was an aero noise from the top of the wind screen. No oil under car this morning, and THE BLOODY NOISE IS NOT THERE THIS MORNING !!!!!
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 774 ![]() ![]() ![]() |
Neither does a wheel bearing noise! ![]() In fact, a wheel bearing will typically become a more pronounced noise when turning - specifically in one direction over another. Also, if the noise has now disappeared it could still be a wheel bearing as they can take some warming-up before they start to moan again. If the noise starts after some time (often dozens of miles) and is probably more noticeable on a particular type of corner then you've got your answer. If you hear the noise again, try covering the brake pedal with a very light foot - enough to put your brake lights on but not to slow you down. See if that stops it........ ![]() Oh, and if you still hear it when the car is stationary........ check for female passengers. ![]() ![]() |
Just recently mine has started making a sort of droning sound , more noticeable when slowing down without touching the brakes |
Thats what i meant when i said it doesnt go away !!!! It doent "change" on left or right handers, also it started last night after a couple of mins of driving. I have a problem in that i can hear grass grow, any little noise and i hear it, sometimes i whish i didnt know a thing about cars and was nieve to the fact things break !!! |
Another option.
THAT COULD BE IT !!!!!!!!!!!!!!! |
@VMPP
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 ![]() ![]() ![]() |
I'm not sure which variant of FFRR you have (TDV8?) but when it's cold, the engine will rev higher than it does when it's warm for the same speed. This is all 'normal' and is to do with the car trying to warm it's oil (and gearbox oil) as quickly as possible. To quantify this, I live within a mile of a main trunk road (dual carriageway). On a cold morning, I can get out onto the main road and be showing 2500rpm at 70mph. Within a few miles, this drops to the normal 2k revs and there is a resulting hush from the engine. I'd liken the warm-up revs sound to an engine racing a bit with a slipping clutch. Just another thought............. ![]() ![]() |
While you were here, you should have taken a few days off, at least untill the weekend, to check out the beaches of Algarve, very good. Golfing also a good option. You should have enjoyed it while we still have a country. Maybe this time next year we'll be spanish property... |
