Home > Technical (L322) > 5x Starter Motors Burnt out. What can be the cause? |
biffa Member Since: 27 Aug 2011 Location: Chelsfield kent Posts: 19 |
Hi. My 2009 Vogue is pretty perfect apart from one thing.
25th Jul 2015 2:11pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The commonest cause of starter motors to burn out is old age, but you've got that one covered! The second most common cause of starter motor burn out is the starter sticking on, or staying engaged after starting. This can be either a build up of dirt which stops the gear retracting when you let go of the key, or could be a short in the ignition, holding the starter motor in the start position when the key is released. Could also be a sticky starter relay, which would have the same effect.
25th Jul 2015 10:10pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Are they reconditioned starters? Are they definitely the correct part number for your ffrr? Previously..
25th Jul 2015 10:19pm |
Amazing Member Since: 17 Jun 2015 Location: China Posts: 61 |
extra load, does engine stop dead quick when off? try turn from crank,check aircon clutch
26th Jul 2015 6:35am |
