Home > Maintenance & Mods (L322) > Rear wishbones and bushes
Madyaker
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
Hi all, the back end has developed a really loud squeak every time I go over any sort of undulation in the road. From what I gather on here it is probably the bushes that are worn. My indie says he is reluctant to change them one at a time and to be honest I agree with him. If one is gone, the others can't be far behind. My question is can the wishbones (upper and lower on both sides) be bought with all the bushes already in or is it a case of buying all the bushes separately, removing the old ones and fitting them seperately to my existing wishbones ? Either way up, does anyone have any favoured buying options/suppliers for these parts other than the stealers ?
looking forward to the replies cheers.
Post #338222 20th Jul 2015 8:30pm
Unlikely to be the wishbone bushes, squeaking from the rear over bumps is usually the top and bottom hub bushes, they are an enclosed rosejoint and when they dry out they wear and squeak like mad..
Around £35 each (there are 4, 2 each side)
I'd get new bolts, nuts and washers as well and then you will have to have the suspension set up as the top ones control the rear camber. Pete
Post #338226 20th Jul 2015 9:01pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Sounds like the same problem i had a while back. Rose joints replaced and all is good (apparentlythey were a pig to get off though!).
Post #338261 21st Jul 2015 1:14am
Agree with the others. Having done a full strip down and replacement of all wishbone bushes at the rear, I found no or very little wear on the inner bushes. Best replace the upper and lower outers first (either buy or cobble together a bush pressing kit)
The dry weather has led to many FFRR owners raising concern about squeaky rear ends though, me included!
Check wiki for howto .
Post #338675 23rd Jul 2015 1:25pm
Indeed Joe it was your excellent write up that saved me a fortune when mine started squeaking and I presumed it was the bushes, then realised it probably wasn't...
Mind you, just done both front lower arms and the bushes on them were well gone... and all the ball joints... like a new car now... Thumbs Up Pete
Post #338710 23rd Jul 2015 3:29pm
marky777
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Bonatti Grey
Exactly the same as i had for the last couple of months, same symptoms etc and very annoying. Panicked it was subframe/wishbone bushes, popped into a local garage who was too terrified to touch it so went to my local MD. They were great and suggested i pop it in when it is squeaking heavily and they would test drive it and stick it on the ramp for free Shocked i took it in and the tech said it was a rosejoint after driving it. I will book it in shortly Very Happy
Post #338716 23rd Jul 2015 3:58pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
I've got to have the rose joints done on mine over the next couple of weeks, sounds like a squeaky old bed spring as im driving up the road !
Big Cry Semper in merda sumus, solum altum variat !!
Current: 2011 4.4 TDV8 Vogue SE
Last one: 2003 3.0 TD6 Vogue
Post #338729 23rd Jul 2015 5:03pm
Madyaker
thanks for the replies guys. Out of interest, what is the worst that can happen with worn bushes ? I've got all 12 bushes plus washers and bolts being replaced by my mate the mechanic on Monday, he reckons its 2 days of a job. I'm taking no chances as i'm towing the tin tent plus grandkids to cornwall next week.
Post #338800 24th Jul 2015 7:26am
Theoretically the wheels fall off... although you would stop driving a long time before that, if the bush totally wears out it will start wearing the bolt that holds it in and then that will fail, however the bolts are huge on a Range Rover and would take years to wear out...
Ball joints however will wear to a point and then break, again though you would have stopped driving a long time before that happened as the noise would be telling you something...
Talking of bolts, I hope you have bought new ones for the bushes, the nuts fitted are one use only, the bolts will be in pretty poor condition... I have snapped two so far when removing them...
Which 12 bushes are you changing?? Pete
Post #338815 24th Jul 2015 10:54am
Worn bushes usually show up with excessive tyre wear either on the inside or outside, plus noises and poor handling. Sometimes this can be sorted by turning the adjustable bolt on the top bush, but this is only really useful if you have alignment equipment.
And I hope you are changing the tracking control arms (REAR) as well (there is an adjustable bolt on there too) Thumbs Up
You will need a four wheel tracking and alignment done when all are changed. .
Post #338831 24th Jul 2015 12:35pm
Madyaker
Thanks guys. I have all the bolts, eccentric washers, nuts etc and I did know about the 4 wheel alignment needing to be done. I went to a LRparts place more or less next to the JLR plant in Halewood and was looked after very well. They were short 1 bolt but posted it and it arrived next day (today) in a box measuring 15"x10"x 10" ! The bushes are for both wishbones on both sides, =12 bushes.
Post #338843 24th Jul 2015 1:08pm
Good luck with it, that should sort it out...
My hub bushes were toast but my original wishbone bushes after nearly 140,000 miles and 13 years are still absolutely fine.... Pete
Post #338847 24th Jul 2015 1:14pm
