![]() | Home > Maintenance & Mods (L322) > Rear wishbones and bushes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Unlikely to be the wishbone bushes, squeaking from the rear over bumps is usually the top and bottom hub bushes, they are an enclosed rosejoint and when they dry out they wear and squeak like mad..
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Sounds like the same problem i had a while back. Rose joints replaced and all is good (apparentlythey were a pig to get off though!). |
Agree with the others. Having done a full strip down and replacement of all wishbone bushes at the rear, I found no or very little wear on the inner bushes. Best replace the upper and lower outers first (either buy or cobble together a bush pressing kit)
Indeed Joe it was your excellent write up that saved me a fortune when mine started squeaking and I presumed it was the bushes, then realised it probably wasn't...
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 ![]() ![]() ![]() |
Exactly the same as i had for the last couple of months, same symptoms etc and very annoying. Panicked it was subframe/wishbone bushes, popped into a local garage who was too terrified to touch it so went to my local MD. They were great and suggested i pop it in when it is squeaking heavily and they would test drive it and stick it on the ramp for free |
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 ![]() ![]() ![]() |
I've got to have the rose joints done on mine over the next couple of weeks, sounds like a squeaky old bed spring as im driving up the road !
Madyaker Member Since: 13 Apr 2015 Location: Wigan Posts: 39 ![]() ![]() ![]() |
thanks for the replies guys. Out of interest, what is the worst that can happen with worn bushes ? I've got all 12 bushes plus washers and bolts being replaced by my mate the mechanic on Monday, he reckons its 2 days of a job. I'm taking no chances as i'm towing the tin tent plus grandkids to cornwall next week. |
Theoretically the wheels fall off... although you would stop driving a long time before that, if the bush totally wears out it will start wearing the bolt that holds it in and then that will fail, however the bolts are huge on a Range Rover and would take years to wear out...
Worn bushes usually show up with excessive tyre wear either on the inside or outside, plus noises and poor handling. Sometimes this can be sorted by turning the adjustable bolt on the top bush, but this is only really useful if you have alignment equipment.
Thanks guys. I have all the bolts, eccentric washers, nuts etc and I did know about the 4 wheel alignment needing to be done. I went to a LRparts place more or less next to the JLR plant in Halewood and was looked after very well. They were short 1 bolt but posted it and it arrived next day (today) in a box measuring 15"x10"x 10" ! The bushes are for both wishbones on both sides, =12 bushes. |
Good luck with it, that should sort it out...
