![]() | Home > Technical (L322) > Is there a way to get new style 2010+ Key to work with 2007 |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
But the 2010+ is keyless entry/start sir so........ How could it work? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35509 ![]() ![]() |
you can change yours to a 2007-09 flip key... ... - .- -.
dbarr1980 Member Since: 04 Apr 2015 Location: Glasgow Posts: 31 ![]() ![]() ![]() |
I'm the same, would be interested in getting upgraded to flip style |
search 'flip key'...there's loads re this and member daveo is the expert.... |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I'd be interested in a flip key but I thought they didn't work on a 2007, only the older models |
is this the thread fish?
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
Hi Sql, I have the same issue. Unfortunately the upgrade to flip keys only works on pre-'07 cars. Had it confirmed from several sources including an auto locksmith. Looks like we have to put up with these things...unless I've missed something. Life is what happens while you�re making other plans. |
No Stan, that's not the thread I was reading. |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
When converting an early key ( 2003 ) to a flip style one, does the cut key from the first one fit in the flip one or is it only the electronics that are transferable ? |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 251 ![]() ![]() ![]() |
EDIT: OK, so I can change to a 2007-2009 flip key. Thanks!
My 07 VSE came with 2 flip keys. TBH I've never seen one of those pictured above on a car where the ignition was on the dash, i.e. a full facelift 07MY version rather than the "in-Betweenies" which were facelifted outside but retained the older interior where the key was down by the gear lever. |
My 07 has the ignition on the dash but has the old fixed key fob |
Same here. Swiss market MY07, first reg 12.06. Non flip style key but facelift interior with dash ignition.
