![]() | Home > Maintenance & Mods (L322) > Observations after Transmission service |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
So the neurotic paranoid person I am with unknown vehicles had such a freak out over every unknown sound on my trip. First I was sure the TC droning was back as soon as I hit the highway. Then it seemed to change in tone. Then it changed in tempo. Then it was irregular. Yet we were still moving and no warning lights. As I tuned my ear to every subtle unfamiliar sound I started to remember that this has new tires and won't sound like my other cars. Also wind! It makes sound and different sounds at different speeds. Eventually I figured it out and now about 700 miles I still haven't heard the sound I heard before the fluid change. I hope to do the next 5 liters this week and I will pay close attention to fluid temp. I have one questions. Does the overflow need to stop dripping before plugging or just become a small fine line of dribble? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Small fine dribble.
Yes thanks. I'm going to play with my thermal reader tomorrow. I do believe the horror stories about RR is because of dealer costs and lack of the critical maintenance.
Last week end I was on a dirt track 50km from help.
OK all, and Phil, about to do my second 5 litre drain and fill on the transmission. I have noticed this rumble/low frequency drone returned after about 3k miles but it is a bit different. Its tone is so similar to the tone of the compressor(not different) and only happens in 5th around 1200 rpms. Does not happen without a constant throttle. That is to say it stops with any acceleration or coasting. No longer sounds pulsed like driving over rumble strips. Does not change with sport mode. I will be more precise with transmission temp and final fill level this time. I believe the iidtool may give me a more precise temp than my IR reader. Anything I should be observant of after this change? |
What sort of temps did you see with your IR reader?
I believe before my first flush it was high in the 120c range. I had to drive about 45 min with a fair elevation climb. I dismissed the temp reading as error because the IR reader was new and I assumed the fill temp was normal operating temp. Recently after a normal warm up temp read about 90c at the front of the pan and about 82 the rear of pan. I will compare the IR reader with iidtool readings and do a correlation. |
120c is smoking hot. Hopefully that is incorrect.
I'm sure it wasn't that hot. I had been switching between F and c. Pretty sure I saw 175F then at one point. Since then I don't recall seeing over 90c at the front pan. |
UPDATE: so nice to have the BT iidtool. I drained the transmission pan for a second time n 3k miles. I will post a picture of the mud milk chocolate colored fluid later. The first fill took 5 litres. So far the second fill has only taken 3. I'm letting the transmission cool a small bit and recheck. The iidtool was reading 41c while the IR reader off the pan was reading between 27c and 33c depending if reading taken off the front or rear of pan. I must assume the transmission temp sensor is correct and it went from 37c to 41c in about 5 min. It was holding 41c for a couple of minutes and probably would have stayed there a while longer but I want to do this by the book even though I can't imagine 1 degree would make any significant or measurable difference. |
I stand corrected. Upon better light of the day the fluid is a good dark brown. Not quite as black as the picture shows. Smells very much like the new oil. No discernible particles either. I'm "assuming " the detergent affect of the last drain and fill is working well. Since I can get the oil for $10/liter and I started with 11 liters I'm going to drain and fill a couple more time in the next couple thousand miles. I'd like to see near new looking oil drain out at some point and see what changes with the torque converter and shift points.
That fluid doesnt look perfect but not as bad as I have seen it.
Not so bad these days with the iidtool. The normal off road height was just about 1 inch too low. So with a tweak of the iidtool I have my needed clearance. If I do the drain and fill in the morning I can finish before the exhaust gets too hot to bump into. |
Ok sorry been a while getting back about the temp.
