![]() | Home > Maintenance & Mods (L322) > Observations after Transmission service |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Just changed pan fluid again after 1000 miles. As you can see by the picture it is still far from clean. Transmission seems even smoother. The majority of the low rpm fifth gear drone was gone after the second fluid change but for a slight odd feel going up hill just before a down shift. If you didn't know this transmission you wouldn't think anything was off. I plan on another drain and fill in about 3000 miles. I will continue this until I see fluid that still has some resemblance to that new honey color.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
This is a useful thread - thanks for the info - I have my trans oil change due (got everything ready - just need the time)
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Unnecessary quote removed
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Hi
Flushing is a different process.
We are talking about the BMW era 5hp24 transmission. You have a 2012 which I assume has at least the ZF 8HP? Plus they got smart and do have a somewhat proper fluid change interval vs our "sealed for life" mistake. If your change interval is in the 50k mileage range and you are not towing an Emirate pocket cruiser (a boat between 40 and 50 feet) you should have a long life with your RR. Just be sure it gets well cooled. |
How do you mean - do you mean I should get a upgraded Oil cooler as I was thinking about this last month from someone like AHF Fabrications I goggled. Charge Cooler http://www.ahfabrications.com/index.php?cP...3td5fmfbl7 ?????? What do you mean by:
Surley a car with 1 million miles on it - would not have the same oil in the transmission box - or are they saying the life of the average owner is approx 3 years ? - is that where they get the Sealed for Life Philosophy from I have seen a DS3 with 480,000 on it RR P38 I read with interest that you change your: Transmission filter is this easy to do - if so how many hours from start to finish would it take - any special tools ? - is it easy to get to on a scale of 1 to 10 ? Thank you both again for writing in ![]() . |
I assume it gets real hot out there. I would also assume the dealer would advise you if you needed extra cooling for the transmission. If not just be sure your cooling system is doing its job. Since you bring it to the dealer for service I assume they check it.
Yes reasonably easy to change filter, you need a set of torx tools. Everything is well accessible on the underside of the FF extended height range and drive up onto 4 bricks and you have plenty of room under there. Cleaning the pan is probably the worst of the job along with the six odd magnets in the pan. Things are a bit drippy when the pan is off. you want a wind free day if you are outside doing this, you dont want dust or grit getting blown into the workings of the trans when the pan is off. 2 hours or less with no trouble at all. Pretty handy to have a helper I would say. If you are not mechanical I wouldnt do it as the torx tools/bolts can be stripped if you dont understand torquing things up and or placing the tool in the head of the bolts correctly. |
Hi P38 & Doclees
You have a different pan to the earlier L322.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
It's not a filter, as such. It's more of a coarse gauze
