Home > Technical (L322) > Ticking |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
Ticking is usually associated with a CV joint, if it wasn't secure for even a short time grit can get inside and damage it, jack it up and check for play.... Pete
16th Jul 2015 7:46pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
I had a horrible feeling someone would say that. I am pretty sure you are correct. I am mot sure whether to attempt this myself. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
19th Jul 2015 10:42pm |
They are a bit of a faff to do, you also need a special puller to get the drive shaft back through the hub, you can DIY it but it's not as easy as a lot of cars.... Pete
19th Jul 2015 11:55pm |
