Home > Technical (L322) > Ticking
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Ticking
For a week or two I have had a ticking noise. I originally thought I had a stone stuck in the tyre tread as that is what it sounds like.
I have poked around underneath to see if any thing is loose but no joy. Recently had a CV joint gaitor come loose but that os now repacked with grease and secure, so not that.
Now wondering if it is anything mechanical. Only audible when moving.
Any suggestions? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #337604 16th Jul 2015 7:29pm
Ticking is usually associated with a CV joint, if it wasn't secure for even a short time grit can get inside and damage it, jack it up and check for play.... Pete
Post #337611 16th Jul 2015 7:46pm
RRBlue
I had a horrible feeling someone would say that. I am pretty sure you are correct. I am mot sure whether to attempt this myself. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #338077 19th Jul 2015 10:42pm
They are a bit of a faff to do, you also need a special puller to get the drive shaft back through the hub, you can DIY it but it's not as easy as a lot of cars.... Pete
Post #338080 19th Jul 2015 11:55pm
