Home > Technical (L322) > GERRRRRRRRRRRRRRRRR Parking sensor !!!
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Ok parking sensors not working, continued beep followed by silence and flashing light at button ?
Any ideas ?
Post #33780 26th Oct 2010 2:59pm
dan_uk_1984
The long beep is to warn you that they are not working so you don't go reversing into something. If you do a search you'll read about people listening to the sensors outside the car, you can hear them "clicking" the one that doesnt click is defective.
However, the system may disable itself as it's obviously detected an issue. The dealers diagnostics should be able to tell you what's up. I'm sure someone will come up with additional solutions soon.
Dan
Post #33786 26th Oct 2010 3:27pm
David
Dan
DAMMMMMMM
You beat me dan !!!!
I did a search just after i posted !!! (wrong way round) I knew you youd tell me to do it !!!!
Anyway ALL front sensors are "clicking" one rear sensor not working ! Whats the fix guys ?
Post #33787 26th Oct 2010 4:02pm
could it be the very off side sensor thats not working.....the wiring is chaffed.... ... - .- -.
Post #33791 26th Oct 2010 4:16pm
David
dont get ya !!!
As you look at the car its the one on the right at the back. not clicking
Post #33812 26th Oct 2010 4:46pm
thats the one dave, same one went on mine and it was the wiring behind the sensor... ... - .- -.
Post #33813 26th Oct 2010 4:47pm
David
how do i check, is it a bumper off job ?
Post #33820 26th Oct 2010 4:57pm
not sure , i didn't do the job but if it is then i shouldn't think it would be hard to do.. ... - .- -.
Post #33822 26th Oct 2010 5:04pm
