Home > Maintenance & Mods (L322) > Rear Amber indicators to clear?
Andy
Just saw a post on the Land Rover owners forum on Facebook about changing the rear light clusters to the 2005 spec with clear indicators and someone replied that it's cheaper to just remove the amber lens from the old style cluster. He didn't say how though.
Anyone aware of this mod? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #337238 13th Jul 2015 4:42pm
are you sure it wasnt the amber side strip they were talking about, i cant recall seeing anything about the actual lens being changed. ... - .- -.
Post #337248 13th Jul 2015 5:31pm
I was thinking along the same lines - it may be cheaper, but it certainly wouldn't be easy - you'd need heat to take the unit apart - the amber lens is probably not easy to remove - the clear lens wouldn't be available as a separate part, so you\'d need to fabricate something......
I know if I tried it, it would work out more expensive - as I would give up and by clear units after having ruined a perfectly good amber unit Whistle
Post #337250 13th Jul 2015 6:10pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Facebook.....nuff said Rolling with laughter
Post #337252 13th Jul 2015 6:16pm
Andy
10 mins per side apparently
Post #337255 13th Jul 2015 6:39pm
Good luck Thumbs Up
Don't forget the photos for the detailed step by step guide you'll be posting afterwards Whistle
Post #337256 13th Jul 2015 6:42pm
didnt know that...as above ,pics please. Thumbs Up ... - .- -.
Post #337257 13th Jul 2015 6:44pm
Andy
This is the finished result apparently
Needs an Amber bulb fitting as well - but you knew that! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #337258 13th Jul 2015 6:55pm
Get the silver bulbs that flash amber - but you knew that Wink
Post #337260 13th Jul 2015 7:05pm
Oh this is a real old trade secret...
Remove the light, take off the bulb holder, take out the silver indicator bulb holder, remove the brake light LED pack. Then you should see all the way down into the light. Tap the inside of the amber reflector/light cover with a screwdriver handle GENTLY!!! and it will shatter (like an egg shell) take the bits out and VOILA... Rebuild using an orange ind bulb instead of the clear one Thumbs Up
Post #337261 13th Jul 2015 7:06pm
pair of used lights here on ebay for £50, just in case you want to practice on them,
http://www.ebay.co.uk/itm/Land-Rover-Range...1c5617311a ... - .- -.
Post #337263 13th Jul 2015 7:27pm
Andy
Doesn't look too bad?
Post #337264 13th Jul 2015 7:33pm
paulandson
hi there did they both go okay , this might have saved me buying a pair of rear lights.
Post #338192 20th Jul 2015 8:28pm
Andy
I haven't done it. I might buy a spare set and butcher those! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #338200 20th Jul 2015 8:40pm
johnboyairey
before you break some eggs, remember that those clear/orange bulbs are about £13 each..
they look a bit blue/green when off, so consider that before you have them naked in the light assembly, ie with no lens.
Post #338225 20th Jul 2015 9:50pm
