Home > Technical (L322) > Lower Control Arms | Vogue 2008 SC |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I don’t see how changing an air strut will have any affect on the steering wheel positioning sir If there is an issue with lower arms? I would simply change all four, so parts 3468 & 3A052 in your image. I would also have the two steering track control balljoints checked & changed if necessary too |
13th Jul 2015 3:48am |
luv2xlr8 Member Since: 29 Mar 2015 Location: Dubai Posts: 57 |
I told the service advisor the same, either hes really or just buying time cause they are busy...but the arms do need changing as they mentioned it on the doc received "steering arm bush crack" ...This is referring to the bushes or the whole front lower arms. Which make should I go for delphi?
13th Jul 2015 12:04pm |
Cam? |
14th Jul 2015 8:17am |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
Hi mate, decent mechanic should be able to handle the job,
14th Jul 2015 10:34am |
Thanks Jake. |
15th Jul 2015 5:47am |
Parts Purchased: Delphi front lower arms £55 x 2
15th Jul 2015 6:19am |
ooo, i love it when nice new shiny parts arrive. its like christmas. 2003 Range Rover Vogue 4.4 on Gas
17th Jul 2015 10:01am |
indeed sir …so a few shots attached of the lower arm replaced…Shiny ..
17th Jul 2015 3:04pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8244 |
Nice, just ordered that lot from Dan for mine today.... Pete
17th Jul 2015 6:11pm |
That's some clean looking parts and 'underneath' for a 2008
18th Jul 2015 4:09am |
thats another plus for dubai then along with long straight roads, lots of sand and no salty / rainy roads. but then we do get snow @pete are you doing more spannering then? will there be lots of pics and a n in-depth write up? @luv2xlr8 nice one fella, they feel even better dont they. thats another job crossed off the list 2003 Range Rover Vogue 4.4 on Gas 1961 88" 2.25 diesel - George Gone - 1997 3.9 V8i Discovery - Burt |
18th Jul 2015 6:43am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Sand is pretty aggressive though. My brother worked in abu Dhabi for ten years and was constantly changing suspension parts due to the wear and tear that the sand caused . |
18th Jul 2015 7:58am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
heat probably kills any rubber parts pretty quickly too. |
18th Jul 2015 9:19am |
Previous owner had about 7 other cars...snatched this one of him (apparently his wife's friendly commute car)
18th Jul 2015 10:04am |
