![]() | Home > Technical (L322) > TDV8 Turbos |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
And another, from a turbo repair specialist
And while we are on the subject of turbo failures ![]()
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
what are you going to say to a parking warden that 'asks you to turn off your engine, or face a fine' this was in the news recently.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Bo |
Well, read rule 123 of the Highway Code, and get 20 pounds out! It's enforcement to control pollution. |
It takes a lot of £20's to cover paying for a new turbo, or 2 |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Wouldn't the fact that you've parked mean you've been pootling about at low boost / exhaust temps so the turbo will already be cool-ish?
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3868 ![]() ![]() ![]() |
FWIW I has a 3.6 for a couple of years and didn't have any problems with the turbo, another member has it now and AFAIK he hasn't had any problems either, I didn't treat the car in any way special. I have had turbo diesels for years and never had any problems and neither do I know personally anyone who has. I don't think I was lucky but rather those that have had turbo problems have been unlucky, problems that I did have, alternator, front and rear bushes etc I pretty much expected around the 75k mark. Geoff |
Cummins!!! That modern TDi manufacturer |
Is Garrett modern enough for you Craig?
TDV8 turbos are not water cooled, FYI... Last edited by Mikey on 11th Jul 2015 5:51am. Edited 1 time in total |
Or HKS?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Depending on where you live, it's not that hard to let it cool down and you will do it without thinking.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Keep your oil clean (and the coirect grade and quality, castrol in my ) and you won't have any problems. I change mine every 5000,
Mickey... You and i will never see eye to eye on anything i post on this site! You have made this perfectly clear!
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
One rule for all turbo applications isn't realistic. It's difficult to compare a small bore low compression petrol high revving compound setup with a larger bore diesel slower revving twin bank turbo setup. ______________________________
