![]() | Home > Technical (L322) > TRANS.FAILSAFE PROG |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
welcome to the forum dimi...
Hi Dimi
Dimi, it could well be your radiator is blocked at the bottom and the gearbox oil cooler is affected. Maybe investigate changing both at the same time? |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Second dolphinboys suggestion, change the main radiator and the gearbox oil cooler. Early l322's had a problem where the bottom 6 rows of the radiator collapsed internally and restricted the coolant flow to the gearbox cooler, causing an overheat and the Texans failsafe mode. |
Dimi Member Since: 10 Jul 2015 Location: Bratislava Posts: 2 ![]() ![]() ![]() |
Hi guys
