![]() | Home > Technical (L322) > TDV8 Turbos |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
No....
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
Like all turbos then........ |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Mine was lovingly looked after. Longer journeys only. Dealer serviced. Etc. Turbo blew for no apparent reason. Bought a Supercharged |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I'd want to remove the egr valves and have them mapped out - as a minimum.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
NMJ -"They prefer to get up to temperature slowly and cool down properly before being switched off."
From what I understand, when under load turbos in general generate immense amounts of heat, I always remember the picture of a lotus esprit engine with its turbo glowing white hot.... The idea of allowing them to run at idle for a short while is to let any heat built up in the turbos to dissipate more slowly and reduce the stress caused by the rapid cooling when you simply turn the car off.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
If you switch off when the oil is extremely hot, the residual heat in the turbos effectively vapourises the oil inside the turbo. It can then stick to the turbo shaft (in the form of carbon), impeding oil flow to the bearings
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
Think I might look at the petrols |
Cooling is less of a problem than you think these days and turbo timers are not necessary , the turbo's are cooled by the thermosyphon principle whereby heat from the turbo causes convection currents in the cooling circuit and draws more coolant round . That said there is a lot of anecdotal evidence that the ERG valves need some kind of preventative maintenance . And maybe good luck as well |
But the turbos on a TDV8 are not water cooled |
Didn't say they were , just saying turbo heat is dissipated from the turbo's and just as importantly the oil left in them by this cooling effect , It's how all modern turbo diesels are designed , unless of course you have thrashed the nuts off the turbo and then shut off very quickly like ,oh I don't know , every motorway fuel stop anybody would do . The people who make engines have thought this through and have eliminated the need to run down an engine , and if you do need to ; it's a bad engine and there is no evidence the 3.6 TDV8 is . 2008 MY Supercharged
Your own 4.2 S/C has an auxiliary coolant pump, to circulate coolant around the engine when switched off, to prevent heatsoak (same principle as allowing turbos to cool down)
I was merely pointing out why modern diesels don't need "spooling down " they are built to cope . two pieces of hearsay and two unassociated petrol engines have nothing to add to this whatsoever |
There is a recurring theme here. If you cant spot it, I'll highlight it again for you Allow your engine to idle for 1-5 minutes to allow the high temperatures and speed to reduce and so prolong the life of your turbocharger. ![]() |
