![]() | Home > Wheels & Tyres > Need new wheel nuts? These are the muts nuts! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Get it?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
very nice and the ultimate nut |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Ooooh. They look good, and I do need to do something about my swollen nuts. |
I have been sorely tempted a couple of times but I just cant get over the price , probably completely justified but , well they are wheel nuts . 2008 MY Supercharged
Crazy money |
ksskaret Member Since: 27 Oct 2013 Location: Tromsų Posts: 73 ![]() ![]() ![]() |
First thing I bought after I had my FFRR |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
I just replaced those that needed replacement, by that I mean those that wouldn't accept the right size socket easily. I did look at the Wrington ones but I would have needed a complete set to keep everything matching rather than the 10 I bought from Dan.
Everybody shut up a little |
Just checked ,$552 . The Mrs is going to kill me |
dont normal nuts have a washer made of steel? ... - .- -.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1394 ![]() ![]() ![]() |
Thanks, I expect so, it seems mild steel with a stainless cover on the nut. I wonder what the downside of using all stainless rather than mainly mild steel would be? Could there be a different reaction with the wheel? (I remember the steel bolt/alloy wing reaction on my Classics leading to corrosion of the wings while the bolts were not affected)
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Certain nuts being stated as "Steel Wheels only" is probably more to do with the taper on them. Steel rims normally use taper nuts where as alloys normally use nuts with a flat washer. Using tapered nuts on alloys that are designed for flat washers will damage the hole in the wheel and likely come undone. There shouldn't be a reaction between the two, as stainless is fairly inert. |
I searched on the topic of galvanic corrosion (as on Classic wings) and found the following comment on the Stainless Steel Information Center of the Speciality Steel Industry of North America site: "...if aluminium structural framing is used to support sheets of stainless steel and they are in direct contact with moisture present, the aluminium's corrosion rate can be accelerated". Moisture is certainly often present in Scotland...
Mild steel can get bi metallic corrosion with ally and they basically weld themselves together. I couldn't really say if it's better or worse than stainless and ally though.
