Home > Technical (L322) > Alternator voltage output..
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Buys what does your system read when the engine running as mine doesn't go above 13.7v which I think is low? I have a feeling my alternator may be on the way out.. Luckily it's only a Td6 so nice and cheap though
Post #336320 7th Jul 2015 6:36pm
Over 14v Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #336323 7th Jul 2015 6:46pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Just had my alternator replaced, did 14 + at start but 13.7 at 2000 rpm with airco etc blowing and the batterylight telling me it was not happy. Now car is happy again. Obviously it seems to be to low and killing your battery also when below 14.
Post #336365 7th Jul 2015 9:56pm
wealy
14.6
Post #336370 7th Jul 2015 10:08pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Are you reading the voltage at battery with meter or looking at voltage though hidden menu on Sat nav screen?
Post #336384 7th Jul 2015 11:15pm
Bungal
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi
How do I find the hidden menu on the satnav screen to see the voltage?
Post #336395 8th Jul 2015 6:04am
Blade74
Australia
I know mine reads 13.7v in the hidden menu.
Not sure if my alternator is ok though.
I'll check with a multimeter.
Post #336408 8th Jul 2015 7:59am
JPS
I am reading it from a meter in the 12v socket in the car as I'm driving.. Would this be an accurate way of telling? There is no battery light on the dash..
Post #336410 8th Jul 2015 8:00am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Bungal wrote:
Hi
Sounds interesting +1 on how do you access this? Question
(14.4V using meter) 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #336411 8th Jul 2015 8:13am
Just a word of caution. If you are going to measure battery voltage you really need to do it accurately given the small but significant differences in voltage that tend to arise.
The best way to measure it is with a decent quality multimeter or voltmeter connected across the battery terminals.
The most convenient way to do it is to fit a voltmeter into the front cigar socket so that you can monitor voltage whilst driving.
Unfortunately in my experience such plug in type voltmeters can be somewhat inaccurate and thus misleading.
I have a couple of these plug in type voltmeters which read 0.4V and 0.5V respectively lower than battery voltage.
It's also worth checking the cigar socket voltage with the battery terminal voltage with a multimeter to check they are actually the same, they should be but...... My cigar socket for example consistently reads 0.3V low compared to the battery terminal voltage, no idea why, presumably a dubious connection somewhere.
If however you know there is such a discrepancy you can just allow for it in readings taken.
As to alternator voltage. Would be looking for a minimum of 14V rising to 14.4 when running on load but it does vary depending on conditions at the time.
From what I have read in the past the voltage outputs displayed by the obc tend to be inaccurate at best and shouldn't be relied on.
Post #336418 8th Jul 2015 9:03am
IIPTool, if left attached constantly reads the voltage output Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #336434 8th Jul 2015 11:22am
JPS
Hi, yes your are correct.. i had one of the voltmeters plugged into the cigar lighter and whilst driving was reading between 13.5v-13.7v.. I went and purchased a good quality multimeter today and tested from the battery with the engine running and aircon on etc, the reading was 14.3v-14.4v so quite a difference and seems my cheap incar ebay special is junk Laughing
Post #336459 8th Jul 2015 3:08pm
Now you have a multimeter it would be worth comparing the cigar socket voltage to the battery voltage.
If anyone is looking for a plug-in voltmeter that will display whilst driving I would suggest one of these.
I have one and it consistently reads accurately compared to a multimeter.
http://www.ebay.co.uk/itm/Ring-RBA3-12v-24...20b51fff8b
Post #336463 8th Jul 2015 3:58pm
Lad
Hidden menu, whilst on the home screen, keep your finger pressed on the top middle of the screen for 5 seconds, then press the navigation button, if these have been done right a keypad then shows on the screen. Type in 753 and the screen shows loads of info over a couple of pages.
BE WARNED NOT TO ALTER ANYTHING WITHOUT KNOWING WHAT YOU ARE DOING. Thumbs Up
Post #336563 8th Jul 2015 11:37pm
